Need Flasher Help - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-23-2019, 07:20 AM Thread Starter
Need Flasher Help
First let me say thanks for having a forum for help. I have an 04 GTO. The emergency flashers wont work. Turn signals are fine. Any ideas on what is going on?
dbauer2004gto is offline
post #2 of 3 (permalink) Old 05-23-2019, 11:40 AM
BLK69JUDGE's Avatar
Quoted: 42 Post(s)
take your foot off the brake ?
BLK69JUDGE is online now
post #3 of 3 (permalink) Old 05-25-2019, 01:48 AM
AlaGreyGoat's Avatar
Quoted: 6 Post(s)
Do the Indicator Lights work in the Instrument Cluster? Does the Hazard Indicator Light work on the Hazard Switch?
Check the HAZARD LAMPS Fuse 15A in the Instrument Panel Fuse Block. Also, check the wiring harness behind the glove box for chaffing.
Could also be a BCM Problem or a wiring problem.
Larry
Schematic attached
Name:	04 GTO Turn Signal Switch and Lamps.png
AlaGreyGoat is offline
  Pontiac GTO Forum > GTO Forum Discussion > Member Introductions
Pontiac GTO Turn Signal LEDs! Plug & Play Install! No "Hyperblink" w/Flasher Module! Diode Dynamics Diode Dynamics 14 06-18-2018 01:37 PM
Ď65 GTO Questions - WS wiper & turn signal flasher Roqetman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-10-2018 07:17 AM
Hazard flasher Install Omni 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 11-27-2016 05:34 PM
65 GTO brake lights, Turn Signal, and Flasher urall8s 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 10-10-2010 08:14 PM
Need help. I need a/c vent temperatures. justin-branam 2004-2006 GTO General Discussion 3 06-20-2009 10:16 AM
