05 W/ 4L65e pressure issue? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-30-2009, 04:07 PM Thread Starter
Issue: Due to harsh winter (MI) car is stored and I start it everyday. Today I noticed Tranny fluid leak. 6" hose up front under Core support had slid down Cooler line ( Tranny side ) and was quarter inch from the furl on the line. I loosened clamp slid back up to furl. Started car and let warm up reinspected hose and sure enough it had slid back down again. Could this be some type of pressure issue or an easy fix by replacing the hose. The hose looks OK but a little on the stiff side. Thanks pags20
pags20 is offline
post #2 of 5 (permalink) Old 12-30-2009, 04:16 PM
MJGTOWISH's Avatar
I would repalce it with the clamps just to be on the safe side.Also check your fuild lvl
¿ʞuıɥʇ noʎ ʇ,uop 'ǝɹɹɐzıq
MJGTOWISH is offline
post #3 of 5 (permalink) Old 12-30-2009, 04:24 PM
Double clamp it, and if you use new clamps be sure to check them in a few days as they have a tendency to stretch.
post #4 of 5 (permalink) Old 12-30-2009, 04:51 PM
jpalamar's Avatar
^ that. And don't start your car everyday while it is stored. twice a month is plenty. You have to run your car until it gets to full operating temp so the water/condensation has a chace to burn off. I'd say 20 minutes at least. Daily is just wasting your time.
04 GTO - sold
jpalamar is offline
post #5 of 5 (permalink) Old 12-30-2009, 05:00 PM Thread Starter
thanks for all the tips! I was kinda stretchen the everyday startemup probably 4 or 5 times a week and I let it run about 15 to 20 minutes. plus I took her out a couple times around the lot when the streets where clear. Thanks again all
pags20 is offline
tire pressure tamerlane57 Wheels and tires 10 06-07-2019 10:01 PM
why no oil pressure guage? Jeffs386 Interior Discussions 9 07-27-2011 01:53 AM
no oil pressure wingnutooa 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 02-14-2009 01:52 PM
Oil Pressure sensors asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-30-2008 06:58 AM
Tire Pressure? 2006GTOLS2 Service, Maintenance and Technical Discussion 13 11-13-2005 02:04 AM
