1967 GTO Power Steering issue - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-18-2019, 08:36 AM Thread Starter
Hi guys, I am having an issue with my power steering. First off, I have replaced the pump and box with replacements from Ames and the system was purged of air etc. The pump was leaking and the pressure valve? In the box went bad causing too much pressure in the pump shooting the cap out of the reservoir. The engine is a 461 and all is fine now. The issue I am having now is after i drive for 20-30 minutes if i make a sharp right or left hand turn into a driveway or at a stop sign or parking spot, I have no power steering. It feels very stiff and i have to fight the wheel. Once I'm parked, or straighten out the steering returns to normal. I am using gm type power steering fluid and there is no leaks,bubbles or whines coming from the box or pump. Any insight would be appreciated.
GtoPaulie is offline
post #2 of 2 (permalink) Old 03-20-2019, 04:11 PM
motown's Avatar
Quoted: 4 Post(s)
Pump swap?
A buddy just had the exact same problem with a big block Camaro resto-mod build. He had to use a Saginaw pump for increased pressure.
I offer this info not knowing what the Ames unit is (or what my pal had in his original setup) I do recall that he had replaced the original pump he installed and replaced it thinking it was defective. After the same problem occurred ...third time was a charm when he installed the Saginaw pump
motown is offline
65 Power Steering issue timmyg 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 08-10-2014 10:05 AM
Power Steering Issue/Sound evanpatchay Drive train, suspension, alignment and brakes. 10 07-24-2014 12:12 PM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
Power Windows, Power Locks, Seat Belts, Power Rear View Mirror, Back Speaker Location GQUINCOCES 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-03-2009 07:18 PM
