2004-2006 Bump stops for the front struts - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-10-2010, 09:44 AM Thread Starter
pcviper13's Avatar
Has any one here used Lovells bump stops on their front struts ? I am in the process of putting my 04 back together and I was going to use lovells bump stops. I tore the front struts down and noticed that the Lovells are longer than the factory ones. If I use theese it would seem like it will shorten the shock stroke. Has anyone here used them ? I have the Pedders 1 inch drop springs in the front with the matching struts if that helps.
pcviper13 is offline
post #2 of 3 (permalink) Old 06-10-2010, 12:21 PM
GM4life's Avatar
Haven't used Lovells bumpstops yet. Your stock stops are shorter maybe because they allready calapsed.
GM4life is offline
post #3 of 3 (permalink) Old 06-10-2010, 01:23 PM Thread Starter
pcviper13's Avatar
I don't think that the factory ones have collapsed that much. The lovells are about 1/2 inch longer than the factory ones. I looked at some Moog bump stops and compared them to the factory ones and they are only 1/8 inch longer. None of them are the same shape, but I don't thnk that matters.
Front Struts & Rear Shocks UdnUdnGTO Drive train, suspension, alignment and brakes. 15 02-25-2010 01:14 PM
Front Struts SPICERED2006 Drive train, suspension, alignment and brakes. 6 12-07-2007 08:33 AM
blown front struts @ 200 miles Russ Schaeffer 2004-2006 GTO General Discussion 6 07-01-2006 12:44 PM
O6 1 Day Old And Front Struts R Leaking Bad!! LS2~N~BLUE Service, Maintenance and Technical Discussion 2 06-10-2006 12:36 AM
