2005 Going Thru Steering Racks Like Crazy - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-28-2016, 08:30 AM Thread Starter
GM Kid's Avatar
A few months back, my high-mileage '05 needed some front suspension work, including a new rack. Shortly thereafter, the car was leaking fluid and smelling awful. (When the rack leaks, it blows back on the exhaust.) Dealer put in a new rack. Same problem. Another new rack. Same problem. Didn't even drive my car today because, on start-up, it was groaning something awful. The dealer has consistently said it's not the pump. QUESTION: Could they be filling the reservoir with the wrong fluid, and if so, would that cause this? I notice the owner's manual says to use Dexron ATF, which is automatic transmission fluid, not DOT 3 or 4 power steering fluid.
GM Kid is offline
post #2 of 5 (permalink) Old 01-28-2016, 09:58 AM Thread Starter
GM Kid's Avatar
GM Kid is offline
post #3 of 5 (permalink) Old 01-28-2016, 02:34 PM Thread Starter
GM Kid's Avatar
The guy at O'Reilly's says Dexron III. I'll give it a try.
GM Kid is offline
post #4 of 5 (permalink) Old 01-28-2016, 08:13 PM
Could also be the hose maybe?? I would try some LUCAS power steering conditioner and stop leak. It can't be bad, they use a `65 blue GTO in the TV ads.
post #5 of 5 (permalink) Old 03-09-2016, 06:15 PM
Grambo427's Avatar
Any luck with this issue? I'm about to replace the rack on my 06 because it leaks like a siev. No pump whine or noise though.
Grambo427 is offline
I might be crazy vance_pounders 2004-2006 GTO General Discussion 18 09-03-2009 08:43 AM
I need some roof racks for my surfboard! LongGoat Exterior Discussions 10 04-21-2006 04:42 PM
Crazy idea....but??? sutliffhl21 2004-2006 GTO General Discussion 5 03-14-2006 11:58 PM
Just Crazy! GTO_400 The Lounge 4 02-18-2006 10:23 PM
OK, this is going to sound crazy.... USARMYTTT 2004-2006 GTO General Discussion 6 11-08-2005 09:11 PM
