2nd Gear Problems - Pontiac GTO Forum
post #1 of 15 (permalink) Old 01-28-2006, 09:53 AM Thread Starter
2nd Gear Problems
Anyone have a problem shifting from 1st to 2nd? Every now and then my car refuses to go into second, and it is not because of the shift 1 to 4 light, it just doenst like to go into second.
MACHINE HEAD is offline
post #2 of 15 (permalink) Old 01-28-2006, 12:38 PM
Could it be clutch related? A sticking clutch caused all kind of problems in my F-body.
Good 2 go is offline
post #3 of 15 (permalink) Old 01-28-2006, 02:07 PM
I've had it a couple of times, only when cold. It would go into 3rd no problem so I drove it without 2nd. Next time in the car it works fine. It feels like a block is on the gate and its not the CAGS as I have mine bypassed. Since I can't reproduce it, I'll wait on a trip to the dealer.
2004 QuickSilver GTO
M6
Stock
SilverGoat is offline
post #4 of 15 (permalink) Old 01-28-2006, 10:49 PM
I have that problem with first gear. Since day one. 1 out of every 12 starts I have to start in 2nd, or realy force it into 1st.
PEARL JAM is offline
post #5 of 15 (permalink) Old 07-24-2006, 09:39 AM
2nd gear problems
I have never had this problem but every once in awhile my car pops out of gear when I'm in second. It only does it in that gear at low speeds. Anyone else have this happen? Also, what is the diff between an M6 and an M12?
GTO_Mike is offline
post #6 of 15 (permalink) Old 07-24-2006, 11:56 PM
bottom line................this tranny is funky. i hope the rip shifter helps this engagement issue out a bit.
enjracing is offline
post #7 of 15 (permalink) Old 07-25-2006, 10:01 PM
Edit: This was supposed to be a reply to Pearl Jam
Every once in a long while mine will do that. I just back it off, let the clutch out, give it a left-to-right shake in neutral, try again, and it goes right in. I've had other cars with the same behavior. I've seen where others complained have had the same thing about reverse while cold, but I've never had that problem.
Gerry
ShoddyHog is offline
post #8 of 15 (permalink) Old 07-26-2006, 11:15 AM
Mine did when new, what I discovered was I needed to pull the shifter towards me when dropping into second during break in and that solved my problem. Seems a slight tug towards your leg was all that was needed. After about 10000 miles it seems to drop no problem. If I could just find 3rd when ripping at 60mph. Good luck.
aintmisbehavinn is offline
post #9 of 15 (permalink) Old 07-26-2006, 11:19 AM
Mine will pop out of 1st if I don't make sure it is pressed all the way. No 2nd gear problems.
post #10 of 15 (permalink) Old 07-26-2006, 03:03 PM
TexasRealtor's Avatar
My SVT had difficulty going into 1st and reverse when at a stop. I tried a "tranny cocktail" with a friction enhancer, which helped a little. Sometimes I had to turn off the ignition to get it into reverse. I think performance trannys are just finicky sometimes.
TexasRealtor is offline
