40k on stock suspension....what would you change today? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 04-01-2010, 01:40 AM Thread Starter
I'm new, and baffled by the Pedders phenomonon. It's really unclear what's really a good investment for a daily driver, and what's above and beyond what I'd need or want to pay for.
My big issue is that I've been shredding tires prematurely under normal use. The inside sidewalls are getting damaged from strut rub. I e-mailed a Pedders guy what he recommended, and he responded that I should get a "no rub kit" consisting of the following:
Part # Component Price
4306 GTO Strut Clevis Bolt and Nut Package, Single Use $15.45
4358 GTO Bump Stop Front Requires 2 packages $36.12
5030 GTO Strut Bearing. $38.57
5851 GTO eXtreme Strut Mount $42.99
EP9019 GTO Urethane REAR Radius Rod Bush $36.62
EP9166 GTO Urethane Front Radius rod bushings and caster adjusters $252.39
PDUSA5409 Pont GTO 5409 Replacement Front Radius Rod Nut. Gm P/N 11076363 $3.99
But I'm not sure if while going to all this trouble, I should just get the shocks/springs/etc replaced. The car has 40k so I'm not sure what the life expectancy is on that stuff. The front suspension just feels sloppy sometimes...and more importantly I'm about to throw on a new set of tires and want them to wear normally. Advice? Any place to get this done and the alignment properly performed around Boston?
GTO-m is offline
Tires for stock 17s and stock suspension jpalamar Wheels and tires 9 03-22-2010 08:18 AM
402HP G8 GXP 0-60 4.7 Sec!!! Under 40K NJG8GT The Lounge 3 05-08-2008 06:55 AM
well I got my gto on the dyno today, bone stock. 06blackgto 2004-2006 GTO General Discussion 9 12-07-2007 04:31 PM
40k Mile Tire Endorsement Groucho Service, Maintenance and Technical Discussion 10 08-15-2005 02:32 PM
