Adding height to rear suspension - Pontiac GTO Forum
post #1 of 15 (permalink) Old 10-20-2009, 12:13 PM Thread Starter
Out of curiosity, is there a way (or product available) that will allow me to add 1-2 inches of ride height in the back? I'm wondering this because I was poking around underneath yesterday, and noticed that my half-shafts are angled up ever so slightly. I don't think it has a positive or negative effect either way, but to me that says there's unused suspension travel available. IF this is true, then perhaps the rear can be lifted to accommodate a fatter tire, like 275 or 285?
Poncho Dan is offline
post #2 of 15 (permalink) Old 10-20-2009, 12:55 PM
jpalamar's Avatar
You can hit 275s on stock 17s by just rolling your rear fender. Also I belive drag bags are a cheap solution that *may* help raise right hight a little, at the least stiffen the rear helping reduce some of that loved wheel hop and give you more room for wider tires.
04 GTO - sold
jpalamar is offline
post #3 of 15 (permalink) Old 10-20-2009, 02:42 PM Thread Starter
Do drag bags work like air shocks?
post #4 of 15 (permalink) Old 10-20-2009, 03:05 PM
jpalamar's Avatar
BMR Fabrication Inc.
Also BMR is a vender here, I would talk to them.
04 GTO - sold
jpalamar is offline
post #5 of 15 (permalink) Old 10-20-2009, 04:25 PM
Drag bags will lift the car a little plus stiffen the rear spring rate. Give me a call here at the office.
Thanks,
Joe Kubiak
Sales / Tech
BMR Fabrication
813-986-9302 Phone
813-986-8055 Fax
[email protected]
www.BMRFabrication.com
BMR Sales is offline
post #6 of 15 (permalink) Old 10-20-2009, 07:20 PM
GM4life's Avatar
I have drag bags under my car. It stiffens up the suspension and you can add or subtract air to adjust height and stiffness. Or you can buy some springs that will raise the rear end up some. Most GTO's I see with stock suspension have spring sag.
GM4life is offline
post #7 of 15 (permalink) Old 10-20-2009, 10:05 PM
I`ve had drag bags in the `65 for over a decade. They work awesome.
post #8 of 15 (permalink) Old 10-21-2009, 06:55 AM
LOWET's Avatar
Do drag bags alter ride comfort at all. My suspension still seems to be fine with 14,000 mile on the clock but I would like to stiffen up the rear a little. Would Drag bags be better then after market shocks.
LOWET is offline
post #9 of 15 (permalink) Old 10-21-2009, 12:35 PM
The drag bags will help stiffen up the rear. They might make it ride a little stiffer than no bags but that will depend on the amount of air that you put in them. I also have koni adjustable shocks available that will allow you to tailor your shocks to your needs. Here is a link to our page if you would like to take a look. If you have any questions please let me know.
Thanks,
Joe Kubiak
Sales / Tech
BMR Fabrication
813-986-9302 Phone
813-986-8055 Fax
[email protected]
post #10 of 15 (permalink) Old 10-21-2009, 08:08 PM
funny you americans wanting to raise the car!
Its an aussie car, its meant to be dragging its ass!!!
dump it hard and leave it that way!
taztassio is offline
Track suspension stillfly131 Drive train, suspension, alignment and brakes. 3 10-09-2009 10:44 AM
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Rear suspension VettenGoat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 05-30-2008 09:24 PM
Report Prompts Investigation Into Pontiac GTO 05GTO In the News 99 06-29-2007 06:13 PM
