Aftermarket rear control arms - help locating - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-24-2016, 10:59 PM Thread Starter
I am having difficulty locating aftermarket rear control arms for my 06 GTO. I need a driver side rear control arm, but I figured if I can find a set of new ones I'll replace both of them. I've already located a used one from a salvage, but they are wanting $160.00 for it. Is that a good price for one?
FNM85 is offline
post #2 of 4 (permalink) Old 08-25-2016, 12:32 AM
GTO44's Avatar
Quoted: 39 Post(s)
There aren't aftermarket rear control arms. You'll have to buy used. With that being said im not sure what a used control arm would go for. I say if you need it and you can't find it anywhere else then $160 is a good price lol.
Also, you'll want to throw a new set of bushings in while it's out of the car, they're pretty cheap.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #3 of 4 (permalink) Old 08-25-2016, 01:25 AM Thread Starter
That's what I was thinking. I work with auto parts and the fact that I couldn't locate the rear control arms was very frustrating. As for the bushings - those are pressed in, correct?
FNM85 is offline
post #4 of 4 (permalink) Old 08-25-2016, 10:42 AM
GTO44's Avatar
Quoted: 39 Post(s)
The new bushings won't need to be pressed in. You just pop them in.
Inner bushings:
LOVELLS/WHITELINE REAR CONTROL ARM BUSHINGS-PAIR-GTO - Kollar Racing Products
Outer "Camber Adjustable" bushings:
REAR CONTROL ARM CAMBER/TOE ADJUSTER 14MM-PAIR-GTO - Kollar Racing Products
If you don't want/need the camber adjustment, you can use the "Inner bushing" for the outers.
If you're doing it that way it's probably cheaper to go with this kit as it's got a full set for both sides:
Control Arm Bushing Set-REAR - Kollar Racing Products
The old bushings will either need to be pressed out, or you can use the "at home" method of removal using a torch.
Here's a video of that DIY method (he starts on the control arms around 3:30)
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is offline
modified rear control arms motoristx Drive train, suspension, alignment and brakes. 8 05-09-2014 04:32 PM
Rear control arms bushing ? bondobill 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 09-23-2012 09:53 AM
Modified rear control arms Ryrob001 Drive train, suspension, alignment and brakes. 4 06-10-2012 10:08 AM
Rear control arms HenryJ63 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 05-03-2010 08:03 PM
tubular rear control arms busaben 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 04-15-2009 05:14 AM
