alignment ccaster adjustment - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-18-2010, 03:27 PM Thread Starter
Just had my 04 GTo aligned. The guy at the shop said the front caster was out of alignment but that the caster was not adjustable. Does anyone make a kit that allows you to adjust the caster? The problem is causing hte car to pull to the right.
fat bastard GTO is offline
post #2 of 3 (permalink) Old 07-18-2010, 10:59 PM
GM4life's Avatar
Yes, get yourself Pedders or Lovells front Radius Rod bushings they allow you caster adjustment. And also improve braking response.
I went with Lovells RR bushings.
Lovells:
2004-2006 Pontiac GTO LOVELLS Front Castor Adjustable Radius Rod Bushings-PAIR
Pedders:
Wretched Motorsports
GM4life is offline
post #3 of 3 (permalink) Old 07-18-2010, 11:40 PM
AlaGreyGoat's Avatar
I agree with GM4life. I have the Lovells and they are adjustable, but a
PITA to do it!
You have to remove the complete bushing shown in GM's pic and move
washers from the front to the back (or vice versa) to change adjustment.
Larry
AlaGreyGoat is offline
Dwell adjustment BobG 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-06-2007 08:20 PM
'06 Clutch adjustment? kegbelly Drive train, suspension, alignment and brakes. 7 05-01-2007 07:52 AM
04 GTO Audio Adjustment ThePrincipal Test Forum 3 01-03-2006 11:32 AM
headlight adjustment HoldenGTO Service, Maintenance and Technical Discussion 7 12-21-2005 07:02 AM
height adjustment LaPuzza Service, Maintenance and Technical Discussion 5 07-14-2005 10:11 AM
