Brake issue - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-17-2015, 09:08 AM Thread Starter
Brake issue
When I first purchased my 04 I had a shudder while braking. After searching many forums I found the brakes would most likely be the cause. So I changed brakes & radius Rod bushings at the same time. Well the shake went away but since I switched from a cross drilled rotor to advanced brand factory brakes I had crappy stopping power & it felt like I had little to no brakes after bleeding them several times. So I decided to upgrade to 05-06 brakes for a while this worked out great. But the shudder came back just not as servere. Over time it got worse. I had my rotors turned (just be fronts) & when coasting to a stop I barely feel them. But when I slam on the brakes from that 60-40mph range man it feels like the car is going to shake itself apart. I think it's the crappy OE brakes & I need to upgrade to a better type however I know it can be the tie rods as well however since this problem changes each time I do something with the brakes it's doubtful. Any advice? I refuse to take it to the track until this safety issue is fixed for good. Any advice would be appreciated thanks.
Supersoldier is offline
post #2 of 6 (permalink) Old 02-17-2015, 06:48 PM
Check the rear rotors too. I had very bad shake on my box truck from rear rotors. I use dial indicator before i start changing or resurfacing. I don't think stock ones are crappy. never had problem with them
Qnko is offline
post #3 of 6 (permalink) Old 02-17-2015, 07:47 PM Thread Starter
Thanks I'll be sure to check my rear brakes
post #4 of 6 (permalink) Old 02-17-2015, 08:17 PM
I've had OE '04 brakes and the last 6 years OE '05 upgrade with no issues. It isn't because they're OE. One other thing to check is your wheel lug nuts. They should all be 95-100 ft/lb tightened in a star pattern. Improper torquing can cause shake.
post #5 of 6 (permalink) Old 02-19-2015, 08:31 AM
SANDU002's Avatar
As Svede said, loosen the lug nuts and torque them alternating every other lug nut. If shake still exits, check wheel studs (loose on hub) and bearings. Just my $.02
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #6 of 6 (permalink) Old 02-23-2015, 12:35 PM Thread Starter
Okay, so after checking everything I found that my LR rotor was serverely warped. That my mess up I should've had it turned when I purchased it. That has greatly helped the wobble but it's still there. So when getting the car back on the lift we found that it has a bearing going bad on the LF. So I'll have to purchase that & it should completely eliminate the vibration from 60-40mph.
Help! Brake rub issue! Flamario Drive train, suspension, alignment and brakes. 12 09-13-2012 09:38 PM
Parking brake issue 04GTO1605 Service, Maintenance and Technical Discussion 5 04-04-2012 03:15 PM
minor brake issue likely just not bleed all the way down... virginiavenom 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 14 10-03-2011 06:46 AM
issue as I begin my brake installation virginiavenom 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 06-25-2011 10:04 PM
Brake Light Issue CharlieZ Service, Maintenance and Technical Discussion 4 08-05-2009 12:11 PM
