Brake light on - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-15-2016, 07:09 AM Thread Starter
Quoted: 6 Post(s)
Brake light on
I replaced the master cylinder and it works great but the brake light is on. Put low level switch back on and connected the wire. The switch is naturally open so I believe if it was broken or disconnected the light would not be on. Do I have to reset something?
johnfin is offline
post #2 of 2 (permalink) Old 02-15-2016, 05:25 PM
Lemans guy's Avatar
Quoted: 55 Post(s)
You probably got that brake pro portioning valve out of center....when it is working right and centered you don't get a brake warning light. When the pressure is uneven like from a leak......then it shorts to ground....
So you have to really make sure. You have no leaks at the fittings first and then a good bleed.....of course you bench bled the MC before you installed it...
No leaks and a good bleed...and the valve should be centered....try that first
Lemans guy is offline
Brake light on? Darth Menace 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 8 09-04-2013 10:52 AM
Brake light problem grabber 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 06-24-2013 08:25 PM
How do I change the brake light Skidmark Service, Maintenance and Technical Discussion 3 06-24-2008 07:11 PM
Brake Light? primerGTO Service, Maintenance and Technical Discussion 1 12-17-2006 08:21 PM
