Brake Noise - Pontiac GTO Forum
post #1 of 8 (permalink) Old 03-22-2010, 11:00 AM Thread Starter
Brake Noise
I have a loud squeaking noise coming from my left rear tire. I have replaced the rotors and brake pad. I also can't get my parking brake to ingage without scrubbing. When I adjust it under the rotor where the brakes work it scrubs.
Lump is offline
post #2 of 8 (permalink) Old 03-22-2010, 02:45 PM
badgoat91's Avatar
wheel bearing maybe?
badgoat91 is offline
post #3 of 8 (permalink) Old 03-22-2010, 02:50 PM
jpalamar's Avatar
What kinda of noise? A sqeek, cluck, grinding, ect?
04 GTO - sold
jpalamar is offline
post #4 of 8 (permalink) Old 03-22-2010, 07:40 PM Thread Starter
Loud squeaking
Lump is offline
post #5 of 8 (permalink) Old 03-23-2010, 08:52 AM
adjust the e-brake till the rotor turns without scrubbing, then readjust the e-brake cable so the e-brake works. While the tire is off check the backing plate to be sure it's not touching the rotor at all.
post #6 of 8 (permalink) Old 03-23-2010, 08:10 PM Thread Starter
I adjusted the e-brake with the screw in front of the e-brake handle but it's still not holding and still squeaking. Is there anything else to do but adjust the brakes under the rotor?
Lump is offline
post #7 of 8 (permalink) Old 03-24-2010, 07:44 AM
I don't think your adjusting it properly. Take it to a shop and have them do it. Be sure to point out the squeaking & the e-brake adjustment.
post #8 of 8 (permalink) Old 04-16-2010, 07:50 PM Thread Starter
Rear end went out on me last week. They are going to replace the whole thing under warrenty so I think this is going to solve all my problem. Thanks for all the help.
Lump is offline
What is that noise??? Ninjured Drive train, suspension, alignment and brakes. 32 07-09-2012 05:00 PM
Off Noise?? SirMarco Engine Discussions 6 11-12-2009 11:12 AM
Engine Noise 6032 Service, Maintenance and Technical Discussion 6 10-02-2007 09:27 AM
04 gto brake pedal noise hanymahi Service, Maintenance and Technical Discussion 2 04-30-2005 12:43 PM
Clunking noise when using e-brake 04m6_ca Service, Maintenance and Technical Discussion 4 04-29-2005 05:58 PM
