Breaks Lock up, Any ideas - Pontiac GTO Forum
post #1 of 25 (permalink) Old 03-19-2019, 10:50 AM Thread Starter
Quoted: 12 Post(s)
1967 Any reason why my brakes will lock up, just took it out after sitting for 10 years ?? Thanks
keiko is offline
post #2 of 25 (permalink) Old 03-19-2019, 11:46 AM
drum or disk? there are several reason why they are locked up. parking brake cable is stuck, therefor engaging the parking brake, it is possible your brake pads have rusted to your rotors. your wheel bearings could be seized. youre going to have to remove all 4 wheels and beat your drums off, or if its a disk, take the whole rotor assembly off and see exactly what is going on.
gmjunkie is offline
post #3 of 25 (permalink) Old 03-19-2019, 06:48 PM
Quoted: 402 Post(s)
If it has been sitting for 10 years, I would go through the brakes. DOT3 brake fluid will absorb moisture just from sitting. Rubber hoses can dry rot & crack. Brake shoes can deteriorate. "Things" get stuck from sitting - gummed up or rust.
post #4 of 25 (permalink) Old 03-19-2019, 11:22 PM
BLK69JUDGE's Avatar
Quoted: 70 Post(s)
rusty drums or rotors can cause extra friction ....
you dont mention if its front or rear or all four or 1 corner
drums rear disc front ? 4 piston front originals ?
leaking rear wheel cylinders ... after sitting 10 years
its master cylinder and rear wheel cylinder rebuild time
have you ever had the brakes done ?
how does the pedal feel real touchy ??
power or manual brakes ??
is the brake fluid low ??
lot n lots of options
time for tires tooooooooooooo no 10 year old tires on my muscle cars .... nooooooo way
unless Im stayin under 35 mph ..... . yah right !!!!!!!!
BLK69JUDGE is online now
post #5 of 25 (permalink) Old 03-20-2019, 09:42 AM Thread Starter
Quoted: 12 Post(s)
OK thanks, I pulled the drums last night which was a hell of a job, needed a puller to do it and a sledge! it was quite a mess. Took everything off to replace new. Just hope I can remember how to put it back together.
keiko is offline
post #6 of 25 (permalink) Old 03-20-2019, 09:50 AM Thread Starter
Quoted: 12 Post(s)
keiko is offline
post #7 of 25 (permalink) Old 03-20-2019, 09:54 AM Thread Starter
Quoted: 12 Post(s)
Thanks for all that posted, forgot to say it was the rear drums, YOU HAVE NO IDEA what it took to get them off. The only thing left is the wheel cylinder which I have sprayed with fluid hoping I can get the bolts off and line disconnected. having said that would anyone know of some good pictures on how to put it back together. I know I am going to struggle with this when the new parts come next week
keiko is offline
post #8 of 25 (permalink) Old 03-20-2019, 11:15 AM
are you just looking to put the new wheel cylinders in? or did you remove the shoes as well? there are many good videos on you tube which will show you how to put everything back together. Make sure your parking brake is working properly and if you are spraying wd-40 or pb blaster in the brakes REMEMBER TO CLEAN EVERYTHING WITH BRAKE CLEANER BEFORE RE ASSEMBLY... brakes dont work well covered in penetrating fluid
God, Country, Cars
gmjunkie is offline
post #9 of 25 (permalink) Old 03-20-2019, 11:37 AM Thread Starter
Quoted: 12 Post(s)
Nope I took everything off, going to start from scratch with new stuff. What should I type in to find the right u tube video ?
Thanks , Deano
keiko is offline
post #10 of 25 (permalink) Old 03-20-2019, 11:42 AM
Thanks , Deano
I just typed in " Drum Brake Replacement" and a ton of videos come up, just look through them until you find one that is closest to yours. They should all be very similar and give you a good idea what to do
God, Country, Cars
gmjunkie is offline
Obama's "Beast" breaks down in Jerusalem! ALKYGTO The Lounge 4 03-22-2013 10:15 AM
What To Do When Your Car Breaks Down; Advice From AAA AutoGuide.com In the News 0 08-18-2011 03:17 PM
Big Oil Tax Breaks GTO JUDGE The Lounge 12 04-01-2008 09:05 PM
6speed transmission noise.. any ideas goatsandstrats 2004-2006 GTO General Discussion 3 10-24-2005 10:59 AM
