Brute power clutch, is it a decent replacement? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-03-2017, 03:26 PM Thread Starter
My clutch is beginning to wear down and I have been looking for a replacement. I only need the clutch to last another 2 years before I swap it out when I actually start modding. Has anyone used the Brute power clutch kit? Or would I be better off just using the Chevy Performance replacement
2006 M6 Torrid Red GTO: K&N CAI, Pypes X box & Axle Back(AKA discount Catback )
MetalDeathtrap is online now
post #2 of 3 (permalink) Old 10-29-2017, 04:20 PM Thread Starter
Never mind all, I appreciate the help...decided to go with a the LS7 LUK clutch kit
Sent from my iPhone using Tapatalk
post #3 of 3 (permalink) Old 10-31-2017, 11:20 AM
GTO44's Avatar
Quoted: 39 Post(s)
Make sure to measure the slave/throw out bearing clearance with the LUK slave. I just swapped a LUK slave into my gto over the weekend. I needed a .055" shim and a .113" shim to bring it into spec (shims are from tick). The base of the LUK is noticebly thinner than the GM slave from tick...
In the pic the LUK slave is on the trans, the GM slave is held underneath:
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
Clutch Replacement johnfin Service, Maintenance and Technical Discussion 1 07-04-2013 08:01 PM
Clutch replacement 2005 what brand? 70gto Service, Maintenance and Technical Discussion 4 05-24-2009 02:09 PM
Clutch line replacement.... exwrx Drive train, suspension, alignment and brakes. 4 06-03-2008 06:03 AM
clutch replacement banshee 2004-2006 GTO General Discussion 9 06-11-2007 08:55 AM
Best Replacement Clutch??? BlownGTO Drive train, suspension, alignment and brakes. 8 02-16-2006 07:18 PM
