cant get trans away from bellhousing - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-21-2018, 04:57 PM Thread Starter
Trying to get trans away from bellhousing to replace throw out bearing on my 2006 gto. Seems to be stuck on the guide pins. Tried to use a chisel that wouldn't budge it. Then tried a putty knife to no avail. Tried 3ft pry bar on rear of trans. HELP
caddyray is offline
post #2 of 5 (permalink) Old 11-21-2018, 08:32 PM
Are you POSITIVE that you've gotten all the bolts out? That'd be my guess...
post #3 of 5 (permalink) Old 11-21-2018, 08:51 PM
Does it separate just a little bit or not at all?
GotTogO is online now
post #4 of 5 (permalink) Old 11-21-2018, 10:29 PM
BLK69JUDGE's Avatar
Quoted: 63 Post(s)
Welcome !!
yah I am a '68 69 guy and my cars all have muncies
I have not had that issue b4
but
xxx2 on 1 more bolt .... unless you have some kind of corrosion going on
be carefull under there .... I dont wanna sound like your mama .... but ...
https://www.google.com/search?q=2006...Ei7e6yctp1oMM:
I am sure you have google it already ....
theres alot of great help here ... but googles your 2nd best friend after us ..............
BLK69JUDGE is online now
post #5 of 5 (permalink) Old 11-22-2018, 09:16 AM
nardulli's Avatar
Send a message via Skype™ to nardulli
I put up a link to the factory shop manual here: https://www.gtoforum.com/f2/factory-...06-gto-132603/
You can download the whole thing or just the section you want.
It will show you a drawing of the trans - bell housing and you can review and then sort out if you have the topmost bolt out. Which I do not think you do.
You are also going to want to buy the Tick performance slave cylinder / throwout bearing with the remote bleeder. Really. I mean - REALLY.
nardulli is offline
Can't seem to get the spark knock to go away. WhittP 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 10-16-2013 07:59 AM
What mods can i get away with and pass emmisions cutlass79500 2004-2006 GTO General Discussion 5 05-03-2012 10:26 PM
Cant get it in Reverse rctach Drive train, suspension, alignment and brakes. 1 07-19-2011 07:39 AM
bellhousing question 66tri-power 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-28-2007 10:36 AM
Why cant I get cyclone gray/red interior? stormy652 2004-2006 GTO General Discussion 11 03-13-2005 06:23 PM
