Car pulls under braking - Pontiac GTO Forum
post #1 of 29 (permalink) Old 03-19-2010, 12:15 PM Thread Starter
Hey guys, new to the forum. I searched around and didn't see a definitive answer. Just bought an 05 6spd, 45k miles. It needs a minor alignment and a few other little things but i absolutely love it.
The issue I'm having, The car drives fine, but under really hard braking, it pulls to the left. The car does need a slight alignment but the alignment pulls slightly to the right. The pads all look even, slides and brake hardware is all greased and good. Anyone have any ideas?
Spastik Monkey is offline
post #2 of 29 (permalink) Old 03-19-2010, 12:28 PM
Get the alignment squared away first, then see what it does.
post #3 of 29 (permalink) Old 03-19-2010, 01:53 PM
jpalamar's Avatar
Wheels torqued properly? Wheels balanced correctly? PSI good? Wheel bearings OK? Bushings? Allignment?
04 GTO - sold
jpalamar is offline
post #4 of 29 (permalink) Old 03-19-2010, 03:00 PM Thread Starter
The previous owner said he has replaced all the front busings on the car with poly. Wheels are balanced, the car has drag bags, I'm running 10psi in both bags. Tires are all set at 35 psi.
post #5 of 29 (permalink) Old 03-19-2010, 05:43 PM
GM4life's Avatar
Bleed the brakes too.
GM4life is offline
post #6 of 29 (permalink) Old 03-21-2010, 09:48 PM
dms
dms's Avatar
having a brake pull, could be suspension, alignment, tires and/or brakes.
for suspension, you could have something causing excess changes in camber,caster and/or toe. Tires to be pressure or a belt. Brakes could be a rotor/or caliper concern.
mike
dms
Michael White
DMS Doing Mike's Stuff
dms is offline
post #7 of 29 (permalink) Old 03-22-2010, 07:45 AM
LOWET's Avatar
Get a alignment . Have the rotors checked and maybe turned downed a little.
LOWET is offline
post #8 of 29 (permalink) Old 03-22-2010, 09:11 AM Thread Starter
Well i've been playing around with it more, and it only does it high speed (75mph+) and it does seem like the suspension shifts left when it does it, i'm thinking a caliper sticking or something jacked with the left side suspension. I'm taking it wednsday to get it aligned
post #9 of 29 (permalink) Old 03-22-2010, 11:11 AM
Sounds like a ball joint or a bushing, again, go get an alignment. They will find whatever is wrong.
post #10 of 29 (permalink) Old 03-24-2010, 08:40 PM
could be the brake hoses. if one of them is swelling then it could cause a pull
Vettekid1992 is offline
Screeching while braking vance_pounders 2004-2006 GTO General Discussion 4 07-13-2009 02:49 AM
Ex lurker pulls trigger Al D 2004-2006 GTO General Discussion 7 05-23-2006 10:52 PM
GM pulls plug on '08 line of cars 05GTO In the News 6 03-29-2005 07:48 AM
The Matadore pulls up in none other than... sboylan 2004-2006 GTO General Discussion 2 01-14-2005 04:34 PM
05 Braking Improvement!!!!! fireitupgto Service, Maintenance and Technical Discussion 1 12-06-2004 09:51 PM
