Changing rear springs - Pontiac GTO Forum
post #1 of 17 (permalink) Old 06-07-2016, 08:20 PM Thread Starter
Quoted: 11 Post(s)
Just bought front and rear Lovell springs for my 06 A4 now I am looking for help installing the rears, are there any videos or write up anywhere?
Plowboy is offline
post #2 of 17 (permalink) Old 06-08-2016, 09:01 AM
Really easy. Take the rear wheels off, make sure the parking brake is off and disconnect the bottom of the shocks. You'll need to push the control arm down just a little bit more. Some have had a friend stand on the arm. I used a small bottle jack wedged between the body and the arm. The spring will just come right out.
post #3 of 17 (permalink) Old 06-08-2016, 01:29 PM
GTO44's Avatar
Quoted: 37 Post(s)
What Svede1212 said! I also used a small jack between the control arm and body to lower the control arm enough to get the spring out.
Here's what I did:
First make sure E-brake is off, not engaged.
Then disconnect the lower shock bolt:
Disconnect the endlink from the sway bar.
Then use a pry bar or jack to lower the control arm enough to get the spring out. If you don't have either you can use coil spring compressors.
The new coil springs should go back in easy then bolt everything back up!
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #4 of 17 (permalink) Old 06-08-2016, 05:46 PM
I've never had to undo the sway. One thing is for sure though, the new springs will literally slap right in as they are a little shorter.
post #5 of 17 (permalink) Old 06-08-2016, 06:34 PM Thread Starter
Quoted: 11 Post(s)
Thank you guys alot I will do this this weekend.
Plowboy is offline
post #6 of 17 (permalink) Old 06-09-2016, 09:23 AM
GTO44's Avatar
Quoted: 37 Post(s)
Just allows the control arm to drop a little further. It's only a 1 bolt so I usually do it when working on the rear suspension
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #7 of 17 (permalink) Old 06-09-2016, 09:25 AM
GTO44's Avatar
Quoted: 37 Post(s)
No prob, Good luck man!
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #8 of 17 (permalink) Old 06-16-2016, 10:03 PM Thread Starter
Quoted: 11 Post(s)
I did this today and it was way easy! Thanks again Svede and GTO44.
Plowboy is offline
post #9 of 17 (permalink) Old 06-17-2016, 11:00 AM
GTO44's Avatar
Quoted: 37 Post(s)
Nice man! How'd it drive?
I know mine felt like a new car after rear springs, koni's, and adjustable rear sway (installed all at once)
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #10 of 17 (permalink) Old 06-17-2016, 05:38 PM Thread Starter
Quoted: 11 Post(s)
It really made a big improvement and wow had the rear springs sagged a bunch. I didn't have the money for the rear Konis yet but I will next month. Now on to the front.
Plowboy is offline
New Rear Springs pocketmaster Drive train, suspension, alignment and brakes. 17 11-24-2013 06:07 PM
Rear springs orelog 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 07-30-2012 03:49 PM
rear coil springs instead of leaf springs jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 01-02-2012 09:52 PM
Rear Springs on '64 pon64gto 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 11-29-2010 06:50 PM
Changing rear end oil??? TESLAFIED-GTO Drive train, suspension, alignment and brakes. 14 07-21-2008 04:50 PM
