clunking front end - Pontiac GTO Forum
post #1 of 12 (permalink) Old 04-23-2010, 08:02 PM Thread Starter
clunking front end
i was turning the steering wheel and i heard this popping noise. not smooth. like something was missing in the suspention or steering. thanks Ralph
lingenfelter cai, vararam tb spacer, v/max ported tb, livernoise stage 2 heads with comp cam 232/232/.50 114 lsa. slp 1 3/4 headers high flow cats, x pipe, qtp cut outs, flowmaster mufflers. tuned by tt performance , highly recomended in n.j.
NEXSTAR7 is offline
post #2 of 12 (permalink) Old 04-23-2010, 11:15 PM
Gunslinger's Avatar
just when you turn the wheel while stopped? while moving?speeds? make noise over bumps or rough road? A little more info needed for any real id of the cause of the noise.
Gunslinger is offline
post #3 of 12 (permalink) Old 04-24-2010, 09:26 AM
GM4life's Avatar
GM4life is offline
post #4 of 12 (permalink) Old 04-24-2010, 11:07 PM Thread Starter
only when stopped. thanks, that was good reading material
NEXSTAR7 is offline
post #5 of 12 (permalink) Old 05-01-2010, 09:09 PM
Gunslinger's Avatar
I get a little sproing sound while I'm turning into my parking spot, so basically turning while almost stopped. It occurs at the very far end of the rotation to the right. It happened before I changed the spring, struts, bearings and it still happens. Not a horrible clunk or pop just a little pop/clunk. Im thinking it has to be something attached to steering.
post #6 of 12 (permalink) Old 05-08-2010, 05:27 AM
vxssls1's Avatar
Send a message via MSN to vxssls1
id check link pins and radias rod bushes
222/224 112
241 ported heads 11:1
comp 918's
OTR
25% UDP
ported TB
4 into 1's 1 5/8,3"cats,twin 3" X force
M6,ripshifter
[email protected],390rwhp
vxssls1 is offline
post #7 of 12 (permalink) Old 05-08-2010, 09:46 AM
Gotagoat's Avatar
Thanks, Mike (DMS), for making the effort to supply the information. Very helpful.
Gotagoat is offline
post #8 of 12 (permalink) Old 05-10-2010, 08:13 AM Thread Starter
well, i was having my tranny replaced anyway so i told the mechanic to check the steering linkages and he went around tightening things. he didnt tell me if he found something, but its not making the noise anymore. go figure. thanks again guys.
NEXSTAR7 is offline
post #9 of 12 (permalink) Old 05-14-2010, 05:04 PM
He may have tightened up on your Radius Rod Nuts. If you hear it any more or your front end feels mushy while negotiating turns,then you may want to replace them with urethane bushings.I had the same problem and I just changed mine.Now it handles like a vette, and of course no more noise.
Goatskin10 is offline
post #10 of 12 (permalink) Old 05-15-2010, 06:47 AM Thread Starter
will keep a ear open. if so who's did you use? pedders
NEXSTAR7 is offline
G8 front end LS6wantabe Exterior Discussions 33 03-26-2010 05:29 PM
clunking from rear end when shifting hard goatfan2004 Drive train, suspension, alignment and brakes. 7 06-10-2009 08:20 AM
Front end work GoToIt 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-01-2004 01:22 PM
