Clunking noise 04 gto - Pontiac GTO Forum
 1Likes
  • 1 Post By HP11
post #1 of 4 (permalink) Old 03-31-2017, 01:26 AM Thread Starter
I recently installed a one peice driveshaft and now at high rpms i hear a very loud clunking noise coming from the rear of the car and you can feel a something hitting the bottom of the car in between the rear seats
Cameron McCracken is offline
post #2 of 4 (permalink) Old 03-31-2017, 09:31 AM
GTO44's Avatar
Quoted: 38 Post(s)
You didn't trim the rear seat belt bolts. They will rub on a 1 piece driveshaft.
You can either grind them down from the bottom of the car, or pull the rear seat and add a few washers to the 2 bolts. I did the latter and was super simple/quick. My 1-piece doesn't rub or clunk at all.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 4 (permalink) Old 03-31-2017, 11:20 AM
GTO44's Avatar
Quoted: 38 Post(s)
Here's a pic of where the rear seat belt bolts would hit the drive shaft. They are ground down in this pic... It'ts easier to just add washers from the inside but either way your clunk will go away.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #4 of 4 (permalink) Old 03-31-2017, 06:28 PM
HP11's Avatar
Quoted: 24 Post(s)
Same principle but we used shorter bolts.
GTO44 likes this.
HP11 is offline
Same noise clunking coming from gearing I T8 I Drive train, suspension, alignment and brakes. 22 06-18-2015 11:01 AM
clunking noise while turning trentwill83 Drive train, suspension, alignment and brakes. 3 12-16-2010 09:38 PM
rear clunking/clacking noise on 05 A4......... pctek Drive train, suspension, alignment and brakes. 34 08-15-2010 09:30 AM
clunking/popping noise - new struts? dustyminpin 2004-2006 GTO General Discussion 2 09-14-2006 03:30 PM
Clunking noise when using e-brake 04m6_ca Service, Maintenance and Technical Discussion 4 04-29-2005 05:58 PM
