clutch for 600hp ls2? - Pontiac GTO Forum
post #1 of 14 (permalink) Old 07-28-2015, 08:25 PM Thread Starter
I have a 2006 gto, 68,000 miles, with suspension upgrade and headers with full 3in exhaust. My throwout bearing just ceased up so I have my tranny out. In the future I am planning on doing engine modifications, either a procharger or stroker kit, either with cam, and get up too 550-600hp. Since I have the tranny out I want to go ahead and put a better clutch in. I'm having troubles finding a clutch that can hold that hp in my price range, around $500 or less. I also want to keep it stock feel for street, it wont be a track car. Please reply with any suggestions. Thanks!
Pro_goat is offline
post #2 of 14 (permalink) Old 07-29-2015, 02:37 AM
Mc leod twin or monster stage 3. If you are not gonna track it you might be fine with stage 2 . I dont think you can find anything good in your price range. And for stock feel with that power you need twin
Qnko is offline
post #3 of 14 (permalink) Old 07-29-2015, 03:19 PM Thread Starter
Do you think a LS7 clutch would hold up?
Pro_goat is offline
post #4 of 14 (permalink) Old 07-29-2015, 05:03 PM
No way. You aren't going to find any clutch that's reliable at that level for under $500. You're proposal of spending many thousands on engine upgrades but want a cheap clutch doesn't make any sense. Your intended use is going to play into it as well. It you want to drag and hook a lot you're going to need an expensive clutch, drive shaft, axles and stubs at the least. A strong street clutch is going to be different than a strong drag clutch. This is not a cheap car to add a lot of power reliably.
post #5 of 14 (permalink) Old 07-29-2015, 08:23 PM
johni53's Avatar
You got that right! LOL
1-7/8" ARH LTs, 3" Magnaflow exh.,Spec twin disc clutch, 402 stroker , Fast 102 w/Nick Williams TB, 1000 hp shaft & axles, cam, fuel & suspension upgrades. 500 rwhp, 484 rwtq
johni53 is offline
post #6 of 14 (permalink) Old 07-30-2015, 07:14 AM
SANDU002's Avatar
+1 what Svede said. Do it right the first time and you will end up saving money instead of spending twice what you originally planned.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #7 of 14 (permalink) Old 07-30-2015, 10:22 AM
The drive train was already pushing the limits with a V8 dropped in from the factory. The platform it was based on was the V6 Commodore.
post #8 of 14 (permalink) Old 07-31-2015, 05:24 AM Thread Starter
Thank you Qnko for the info and suggested clutches.
Pro_goat is offline
post #9 of 14 (permalink) Old 07-31-2015, 10:10 AM
FWIW there are two McLeod twins. The RST is for street use and the RXT is better suited for the track. The Monster 3 is a monster to drive on the street. It has an on/off feel, glazes up easily and squeals and chatters making it a better track clutch
post #10 of 14 (permalink) Old 07-31-2015, 01:04 PM Thread Starter
So is twin the way to go to keep feeling stock, for the street, and be able to hold the hp? Again it wont be a track car.
Pro_goat is offline
Installed Tick clutch master. Clutch pedal feels different. SplitFire Drive train, suspension, alignment and brakes. 12 01-18-2012 05:15 PM
Clutch goes soft after driving spiritedly and other clutch related things Sciggy Drive train, suspension, alignment and brakes. 11 04-02-2011 01:01 PM
chip for 600hp? buying a gto msgts96 2004-2006 GTO General Discussion 14 04-01-2007 11:41 PM
600hp Viper Good 2 go The Lounge 5 01-29-2007 01:32 PM
