clutch - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-26-2015, 05:06 AM Thread Starter
clutch
What would be a good clutch for our GTO's if its bone stocked. need to change mine. what d you all recommend?
romeric is offline
post #2 of 5 (permalink) Old 06-26-2015, 02:46 PM
A full faced clutch like a Centerforce or a Monster 1. Don't get any puck style ones or you'll lose the drive-ability you're used to.
post #3 of 5 (permalink) Old 06-26-2015, 09:13 PM Thread Starter
Cool, what about a SPEC stage 1. Whould that be good too?
romeric is offline
post #4 of 5 (permalink) Old 06-27-2015, 10:46 AM
johni53's Avatar
I have a Spec twin disc but wouldn't recommend it other than the pedal feels like stock. Very grabby when taking off and noisy. Centerforce has good rep but stiff pedal is what I've read about it.
1-7/8" ARH LTs, 3" Magnaflow exh.,Spec twin disc clutch, 402 stroker , Fast 102 w/Nick Williams TB, 1000 hp shaft & axles, cam, fuel & suspension upgrades. 500 rwhp, 484 rwtq
johni53 is offline
post #5 of 5 (permalink) Old 06-27-2015, 01:03 PM
My opinion of Spec is not very good. I had a Spec 3+, had nothing but trouble with it and no support from them. A "Stage 1" Centerforce, Monster or other brands should not be too stiff. To get high HP there are only 3 ways to do it, heavier PP springs, pucks/aggressive friction material or multiple disks. Stage 1 types are moderate HP and so usually don't have real heavy springs although they for the most part are higher HP than stock. It's not a cheap solution but I love my McLeod RST twin. I'ts rated for 700+ HP, is as light as stock and has soft engagement.
McLeod rst twin clutch destroyed need new clutch help mike4387 Drive train, suspension, alignment and brakes. 6 01-17-2014 07:29 PM
Installed Tick clutch master. Clutch pedal feels different. SplitFire Drive train, suspension, alignment and brakes. 12 01-18-2012 05:15 PM
Clutch goes soft after driving spiritedly and other clutch related things Sciggy Drive train, suspension, alignment and brakes. 11 04-02-2011 01:01 PM
