clutch engagement problems (still) - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-09-2015, 05:37 PM Thread Starter
Send a message via MSN to Gto-noob Send a message via Skype™ to Gto-noob
Angry clutch engagement problems (still)
so i got the ls7 clutch, flywheel, pressure plate, new slave for the gto, tick adjustable clutch master cylinder, and the clutch wont engage. the clutch pedal is rock hard and takes a lot of pressure to push it to the floor. I can hear the springs in the slave move. i have bled the slave over and over again, with and without a remote bleeder. ive bought 2 slave cylinders thinking i could have bought a rotten one. the adjustable clutch master cylinder has a small pocket of air and ive tried to remove it but it doesn't move. it will start in a gear but wont come out of the gear. and will lunge forward. Any help would be awesome.
Gto-noob is offline
post #2 of 3 (permalink) Old 03-10-2015, 08:38 AM
I'm not a fan of replacing the master without the stock one being bad. The air in it will make it not work right. Did you measure for slave clearances?
post #3 of 3 (permalink) Old 03-11-2015, 02:16 PM Thread Starter
the stock master was bad. and i did measure and i did not need a spacer for it. i just dropped in a stock clutch. gonna sell the ls7 clutch, flywheel and pressure plate. i fine with the stock 1 till i cam
Gto-noob is offline
Clutch Pedal Clicks at Top of Engagement Common Problem? JeffM 2004-2006 GTO General Discussion 4 06-12-2014 07:45 AM
Extremely High Clutch Engagement Point Wolverine04 Drive train, suspension, alignment and brakes. 3 10-20-2010 10:27 PM
clutch problems... i think gregt7 Service, Maintenance and Technical Discussion 1 10-05-2010 08:24 PM
Clutch problems... bmetzger1988 Service, Maintenance and Technical Discussion 2 04-02-2010 06:24 PM
Clutch problems! POOF 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-16-2007 10:45 AM
