clutch engages right off floor - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-08-2014, 07:20 AM Thread Starter
Just got my gto yesterday, this might be covered somewhere on forum but browsing on phone atm at work . The clutch is a 6 puck unsprung with about 500 miles on it . You can start it with the pedal about 2/3rds pressed but cannot change gears at that height . The pedal engages just off the floor . Previous owner installed it and said it was a cable clutch , anyway to adjust? Thanks again
popwar is offline
post #2 of 4 (permalink) Old 07-08-2014, 06:56 PM
Clutch is not cable but hydraulic and it is not adjustable. Its probably the hydraulic system, most likely the slave. Or it might be just air in the system.
Qnko is offline
post #3 of 4 (permalink) Old 07-12-2014, 04:36 AM
codidious's Avatar
i know that there is a proper way to shim the slave cylinder. I don't remember how to do it. maybe a google search
codidious is offline
post #4 of 4 (permalink) Old 10-02-2014, 11:57 AM
John200871's Avatar
Mine is real sensitive also. I found that my car has a puck style center force clutch that the previous owner installed.
06 m6 pbm gto: torquer v2 cam (112 lsa) from T.S., prc .675 dual spring kit, c5r timing chain, vararam otrcai, msd 2 step, pacesetter LT's, corsa sport catback, catless mids.
John200871 is offline
relay clutch engages jrw63 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-12-2014 08:25 AM
Installed Tick clutch master. Clutch pedal feels different. SplitFire Drive train, suspension, alignment and brakes. 12 01-18-2012 05:15 PM
ebrake engages foreward only... not backword jpalamar Drive train, suspension, alignment and brakes. 3 09-14-2010 01:09 PM
Does clutch need to go to the floor? ponyeater Drive train, suspension, alignment and brakes. 3 07-09-2006 07:31 PM
