Clutch not pulling back up - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-23-2010, 04:06 PM Thread Starter
Send a message via AIM to Suburb Thuggin
When I drive normally the clutch pulls fine however, when I push the car, 5k shifts or higher my clutch will not pull all the way back up. It will stick less than halfway down and I have to pump it several times for it to come back up. Do I need clutch fluid or is it something else?
Suburb Thuggin is offline
post #2 of 5 (permalink) Old 01-23-2010, 07:54 PM
canadianGTO is offline
post #3 of 5 (permalink) Old 01-24-2010, 01:00 PM
Bobbyg's Avatar
Thanks for the link.
Really good info.
Bobbyg is online now
post #4 of 5 (permalink) Old 01-24-2010, 04:00 PM
My clutch at 7K miles was stiff to push, and after flushing it as per the instructions it is soft again. Worked for me.
post #5 of 5 (permalink) Old 01-24-2010, 05:24 PM
i agree that clean clutch fluid is a requirement to having the system work properly but you may find the issue doesn't go away with even a complete swap. another problem not listed in that link is the pressure plate itself. especially on the stock clutch centrifugal force at high RPM prevents the fingers of the PP from pushing the slave back and thus thru the hydraulics to the pedal's return. A replacement of the clutch with a better, performance clutch may be needed to prevent that from happening. i had the same thing and even with a thorough bleeding with a remote bleeder it took a stage 3 clutch and i've never had the problem again.
LS7 clutch vs Monster Level 2 clutch POLGTO05 Drive train, suspension, alignment and brakes. 5 05-26-2010 07:18 PM
Seat seams pulling apart SLVR DOG 2004-2006 GTO General Discussion 2 05-11-2009 10:38 PM
Removing Back Seats & Back Center Piece chucksgto Interior Discussions 4 12-04-2008 08:32 PM
Need help with pulling e brake lever out bwhit Service, Maintenance and Technical Discussion 1 11-27-2008 12:00 AM
Pulling 0.99g hsv The Lounge 2 11-19-2007 07:17 AM
