Clutch release bearing question?? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 07-20-2009, 06:06 PM Thread Starter
AlaGreyGoat's Avatar
I'm about to do a clutch replacement with 122K on the clock.
New Fidanza aluminum flywheel, Spec I clutch, F-Body slave,
pilot bearing, and SS lines with remote bleeder.
It seem that the release bearing will be turning all the time.
On the old fork setup, the bearing only turned when the
pedal was pushed in. The hydraulic setup has a spring that
pushes the bearing against the pressure plate fingers with
the pedal released. Seems this would wear out the bearing very quickly.
Am I wrong on this??
Larry
AlaGreyGoat is online now
post #2 of 6 (permalink) Old 07-21-2009, 10:31 AM
as far as I know most any hydraulic clutch system will ride the throwout bearing on the pressure plate. Kinda like how a brake caliper relieces it's pressure but the pads still rides on the rotors. It's how it's self adjusting.
post #3 of 6 (permalink) Old 07-21-2009, 12:14 PM Thread Starter
Thanks, Rukee,
Just seem like a lot of wear on the bearing.
Larry
post #4 of 6 (permalink) Old 07-21-2009, 03:18 PM
jpalamar's Avatar
I would replace it while you are there.
04 GTO - sold
jpalamar is offline
post #5 of 6 (permalink) Old 07-21-2009, 09:18 PM Thread Starter
The new slave cylinder comes with a new bearing.
Thanks,
Larry
post #6 of 6 (permalink) Old 07-22-2009, 06:53 AM
jpalamar's Avatar
Thanks,
Larry
Good to know. I've read others complain about the bearing failing before their clutch did.
04 GTO - sold
jpalamar is offline
fan clutch question abraxasil 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-12-2010 08:58 PM
O4 clutch question Peetyz Drive train, suspension, alignment and brakes. 4 06-23-2009 03:26 PM
Question 2006 M6-Transmission WZNTME 2004-2006 GTO General Discussion 16 03-26-2007 11:29 AM
New GTO Clutch Question Aceofaces Service, Maintenance and Technical Discussion 6 10-03-2006 09:58 AM
clutch question alptbird Drive train, suspension, alignment and brakes. 4 05-15-2006 12:49 PM
