Clutch Slave cylinder - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-06-2010, 03:20 PM Thread Starter
I have a 2004 pontiac gto and the slave cylinder for the clutch is leaking and i need to replace it. I was told a F-body slave cylinder will fit as long as you change out the Q.D fitting. I dont know what a F-body is ? Does anyone know where i can order the exact slave cylinder i need because finding it has been a pain and really expensive. Thanks
riley70usmc is offline
post #2 of 4 (permalink) Old 03-06-2010, 08:02 PM
Justice's Avatar
Send a message via Yahoo to Justice
F-body = Firebird / Camaro
"Some people are like slinky's. They really have no useful purpose, but they can still put a smile on your face when you push them down stairs."
Justice is offline
post #3 of 4 (permalink) Old 03-06-2010, 10:49 PM
GM4life's Avatar
Yes you can. And yes you just use the QD from your old slave you just push out the roll pin that holds them in. An F-body is a Camaro or Firebird/Trans Am. I just told the Auto Parts counter 2002 Trans Am with V8 w/6 speed. Make sure they order one that has the release/throw out bering. Because they do have them without.
GM4life is offline
post #4 of 4 (permalink) Old 12-26-2010, 02:21 PM
what is the QD??
cain5.7 is offline
LS7 clutch vs Monster Level 2 clutch POLGTO05 Drive train, suspension, alignment and brakes. 5 05-26-2010 07:18 PM
Slave Cyclinder? bwhit Drive train, suspension, alignment and brakes. 9 11-24-2009 11:19 AM
Hmmm...cylinder 4? Cylinder order??? WanaGTO Service, Maintenance and Technical Discussion 3 07-15-2009 08:07 AM
Slave Cyl? squrtdog50 Service, Maintenance and Technical Discussion 2 12-28-2008 05:06 PM
Clutch peddle hydraulic slave henryz Service, Maintenance and Technical Discussion 2 01-22-2008 07:33 PM
