Dealer replaced differential today - Pontiac GTO Forum
post #1 of 23 (permalink) Old 12-16-2005, 12:05 AM Thread Starter
cat1055man's Avatar
'05 owners....I had the diffential whine issue. Picked the car up today after dealer replaced the differential. The whine is greatly reduced. There is still a very faint whine 40-50mph under light decelleration. Also the back lash seems to be reduced. I am pleased with the replacement differential, most would not even notice any noise, I think I am probably just super sensitive to any rearend noise due to having the whine issue and diff. replacement.
If you have noticable rearend whine you can take your car to the dealer, Pontiac has a program to correct the problem...they replace the entire Differential assembly. If the problem exists it will likely happen at 40-50mph under light acceleration and/or deceleration.
2005 GTO, M6, Quicksilver / Black
2003 GTP, Silver / Black, 3.4" Pulley
1994 Z-28, Red, M6, Hotcam, SLPs, Tune
1994 Z-28, Red, M6, stock
1994 Cadillac STS
cat1055man is offline
post #2 of 23 (permalink) Old 12-16-2005, 12:29 AM
04gtolover's Avatar
I have an 04 and had mine replaced for whine on off throttle. Couple thousand miles later whines worse with the foot on the gas.
04gtolover is offline
post #3 of 23 (permalink) Old 12-16-2005, 06:55 AM
Mine was replaced as well. Whine was TOTALLY eliminated.
Pennsylvania Goat is offline
post #4 of 23 (permalink) Old 12-16-2005, 08:13 AM
johnebgoode's Avatar
Mine is on order through dealership. Now its just a waiting game......!!
johnebgoode is offline
post #5 of 23 (permalink) Old 12-16-2005, 08:41 AM Thread Starter
cat1055man's Avatar
It took 2 months to get mine in. I plan to run it 500-700miles and then drain the gear oil. The GM synthetic gear oil and additive is expensive but I think an oil change after initial break in is a good practice because when gears break in they generate fine metal particles as the teeth polish the contact areas...just my opinion
1994 Cadillac STS
post #6 of 23 (permalink) Old 12-16-2005, 08:54 AM
Take it back. That just means they got a differential that was not laser set. All of the new replacements will be set properly, which means that it should completely eliminate the whine.
dealernut is offline
post #7 of 23 (permalink) Old 12-17-2005, 09:11 AM
How many 05 GTO's have the diffential whine issue? 50%
What is the root of the whine?
I have 900 miles on my GTO no whine as of yet.
NT91 is offline
post #8 of 23 (permalink) Old 12-17-2005, 09:25 AM
It was described to me by our GM rep. That the manually set rings in the differential are not set properly and they vibrate against each other. That causes the whine and eventually ends up hurting the rear end.
This guy normally is spot on with his information, but I had a hard time believing that our rearend would vibrate like that.
Anyways he went on to say that the new differentials are set with a laser guided machine and they are always perfect.
post #9 of 23 (permalink) Old 12-17-2005, 10:05 AM
Noisy pinions.
post #10 of 23 (permalink) Old 12-17-2005, 12:12 PM Thread Starter
cat1055man's Avatar
UP-DATE...CRAWLED UNDER THE CAR TODAY TO LOOK AT THE NEW DIFFERENTIAL INSTALLATION. ONE OF THE MOUNTING SOCKETS, CAST INTO THE REAR COVER, FOR THE R.H. SPEED SENSOR IS DAMAGED. LOOKS LIKE THE UNIT WAS DROPPED OR DAMAGED IN SHIPMENT, THE SPEED SENSOR IS MOUNTED AND FUNCTIONS BUT THE BROKEN CAST COVER IS NOT ACCEPTABLE. DIGITAL PHOTOS HAVE BEEN E-MAILED TO THE SERVICE MANAGER. I WILL FIND OUT WHAT NEXT STEPS ARE NEXT WEEK.
1994 Cadillac STS
