Differential insert question? - Pontiac GTO Forum
post #1 of 12 (permalink) Old 11-16-2013, 01:44 PM Thread Starter
I'm installing bushings. I took the differential mount off.
4 bolts on top, then the two that attach to the diff cover.
How do I get the insert inside the mount?
Everything came off as one big piece and I dont see how I can insert it in there.
Energy suspension part 1195
5mgelt1ls2 is offline
post #2 of 12 (permalink) Old 11-16-2013, 02:06 PM Thread Starter
Anyone?
I was kind of trying to get the job done before sun set today
post #3 of 12 (permalink) Old 11-16-2013, 02:57 PM
I put it on the bench, wedged it up against the vise, then used a bar to pry it open.
It went in easy.
GotTogO is offline
post #4 of 12 (permalink) Old 11-16-2013, 03:18 PM Thread Starter
Thanks for the respone.
So it's possible to split the mount into two pieces? I just didn't want to damage it
post #5 of 12 (permalink) Old 11-16-2013, 06:43 PM
Steamwalker's Avatar
Split it? I think you are doing something wrong.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #6 of 12 (permalink) Old 11-16-2013, 08:49 PM
Yeah, don't split it in two. Sorry for the confusion.
I used a prybar to widen the opening enough to insert, the, um, insert.
GotTogO is offline
post #7 of 12 (permalink) Old 11-17-2013, 09:12 AM
Soapy water. IMHO the insert doesn't do much.
post #8 of 12 (permalink) Old 11-17-2013, 10:50 AM
Yeah, I would have to agree.
But you paid for it so you want to use it.
GotTogO is offline
post #9 of 12 (permalink) Old 11-17-2013, 12:37 PM
The Energy one fills only half the voids of inserts like I used (before my Harrop cover) so the benefit I would think would be even less. I'd still use it if I had it though. Doesn't hurt.
post #10 of 12 (permalink) Old 12-13-2013, 11:53 AM
NucciGOAT's Avatar
So the Harrop cover would be a better choice then the insert, I was looking at the Lovells insert myself. I have not been able to find the harrop cover. Where can you purchase it and how much does it cost? I still don't understand how a Diff cover can help reduce wheel hop?
2004 yellow jacket M6: AEM intake, SLP LM2, 05/06 front brakes with DBA slotted rotors & hawk pads, B&M shifter, MSD wires, NGK TR55 plugs, Diablo predator tuned..
NucciGOAT is offline
differential insert bushing? youngGoat 2004-2006 GTO General Discussion 7 02-27-2011 05:17 PM
1964 GTO Differential Question Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 02-17-2011 03:21 PM
Differential Question sbagley50 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 12-21-2009 05:29 PM
Differential question The intimidator Drive train, suspension, alignment and brakes. 2 12-10-2008 03:00 PM
amsoil differential fluid question j3157 2004-2006 GTO General Discussion 6 01-05-2007 11:10 AM
