Do you do your own brakes? - Pontiac GTO Forum
post #1 of 23 (permalink) Old 06-26-2010, 11:22 AM Thread Starter
I'm finally the proud new owner of a 2005 (Thank you, thank you). I've got a minor squeak coming from the rear brakes. I am planning on taking the wheels off to see what's left of the pads. Reading the manual they make it sound like changing the brake pads is complicated. I've changed many a brake pad in my day, and it's never been complicated. Is this just to scare the average Joe into bringing it in to the dealer to pay top dollar? Reading on here, it sounds like there are some good options for upgrading the pads.
bforty is offline
post #2 of 23 (permalink) Old 06-26-2010, 11:29 AM
Falco21's Avatar
One of the easiest things ive ever done.
Take the wheel off.
Get a C Clamp and squeeze the piston in.
Loosen the bottom bolt on the caliper.
Remove the top bolt on the caliper.
Swing the caliper up and pull the pads out.
Put the new pads in and put the caliper back over and tighten both bolts.
Done.
Make sure you pump the brakes when your done so the piston can push back out. Very easy. It may sound hard, but its much much easier than you think. If you have any questions let me know. Good luck!!
Falco21 is offline
post #3 of 23 (permalink) Old 06-26-2010, 12:07 PM
jpalamar's Avatar
So easy it isn't funny. Only hard part is that the rotors tent to be a pita because they don't wanna come off without a big ass rubber mallot. Once you get them off, use some sand paper or a file to get the rust off, then use anti seize.
1. remove wheel
2. remove caliper, 2 bolts
3. remove caliper bracket, 2 bolts
4. remove/replace rotor
5. calip bracket back on and lube slide pins
6. caliper back on and bleed it while your there
7. wheel
Just make sure your ebrake isn't on when you do the rears.
jpalamar is offline
post #4 of 23 (permalink) Old 06-26-2010, 04:30 PM Thread Starter
Thank you gentlemen. That's what I needed to hear.
bforty is offline
post #5 of 23 (permalink) Old 07-30-2010, 08:24 PM
blown goat's Avatar
Take the wheel off.
Done.
yeah what he said. just did mine 2 weeks ago . Used Wagner pads.
Procharged @ 11lbs. Dart heads, Comp cam, Alcohol,
HP Tuners, BMR sub chassis, Axles, driveshaft, drag bags, gauges, 670whp-633Torque.
blown goat is offline
post #6 of 23 (permalink) Old 07-31-2010, 09:44 AM
1. remove wheel
7. wheel
Rubber mallet?? Wholey crappin no-effect Batman!
I use a RBFH between the studs, takes skillz to not hit the wheel studs, but much more efficient/effective then a rubber mallet.
post #7 of 23 (permalink) Old 07-31-2010, 10:36 AM Thread Starter
Changing the pads was a breeze. Getting to the rotors, not so much. Someone must have borrowed Superman's impact wrench to get those SOBs on.
bforty is offline
post #8 of 23 (permalink) Old 07-31-2010, 10:44 AM
GM4life's Avatar
The rotors get siezed on with rust. I use a little grease so I can take them off the next time. Getting them off just use a block of wood and a BFH. Use the wood and hit around the rotor to even the distribution of force and so you won't damage the rotor.
GM4life is offline
post #9 of 23 (permalink) Old 08-04-2010, 04:38 PM
UdnUdnGTO's Avatar
I never could figure out why shops charged more for disk brakes than drum. I think a myth of difficulty has emerged around disks, ain't so. I agree. Disk brakes are a breeze. Hope you haven't scored your disks.....FBH is definitely needed.
UdnUdnGTO is offline
post #10 of 23 (permalink) Old 08-04-2010, 09:47 PM
jetstang's Avatar
Rust? What is that, I just pull the rotor off... Kidding, but not, I'm from Wisconsin but live in FL, gotta hate salt..
Burning rubber since 1982!!
jetstang is offline
Brakes? RJ_05GTO Drive train, suspension, alignment and brakes. 10 06-02-2010 09:31 PM
New Brakes? pickinfights Drive train, suspension, alignment and brakes. 10 03-20-2009 03:34 PM
New brakes! ChiefyGTO 2004-2006 GTO General Discussion 0 05-09-2007 11:02 PM
Brakes Goatsucker Drive train, suspension, alignment and brakes. 6 04-03-2007 04:01 PM
