Drag Bags?!? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-25-2010, 11:49 AM Thread Starter
Drag Bags?!?
I have a 04 gto and I just ordered the drag bags because I have crazy wheel hop and I just wanted to get an idea on wat I need to do or if there are any tricks on how to do the install thanks
04Black Goat is offline
post #2 of 7 (permalink) Old 03-25-2010, 01:41 PM
KyleGT05usmc's Avatar
I do not have drag bags but i've heard you must remove the bump stops but thats all ive seen, i think its pretty simple
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
post #3 of 7 (permalink) Old 03-25-2010, 02:56 PM
Very easy! Disconnect your sway bar end links, shocks, lower control arm bolts, and lower your control arms. Remove springs, cut off bump stops, put drag bags in springs, place back in vehicle, route air lines, and put back together! I did mine one night after work. Very easy! Just make sure you don't route the air lines by anything that will move and break them. There are small holes in the plastic cover at the rear of the vehicle that are perfect for mounting the air valve so at the track all you have to do is bend down by the rear bumper to inflate/deflate. Ican tell you they make a world of difference on the track. I should have put them in the day I bought the car.
mikes06goat is offline
post #4 of 7 (permalink) Old 03-25-2010, 06:37 PM
Too bad you already ordered them. There are other bags (Mazda MPV) that are cheaper, easier to install and don't require cutting your bump stops off.
post #5 of 7 (permalink) Old 03-25-2010, 07:06 PM Thread Starter
Ok thanks
post #6 of 7 (permalink) Old 03-31-2010, 02:29 AM
87GN06GTO07IRL's Avatar
Footballs work great too.
87GN06GTO07IRL is offline
post #7 of 7 (permalink) Old 03-31-2010, 11:53 PM
danfigg's Avatar
re
Are you guys sure those are the bumpstops that are getting cut. Those things hold the coil springs in place and I highly doubt that they ever contact each other and if they did it would cause some serious damage. Bumpstops are usually made of rubber, get bolted in place and keep the car from bottoming out. The rubber pieces that go over them are the coil spring insolators----Danfigg
danfigg is offline
drag bags??? 2004americanmuscle Drive train, suspension, alignment and brakes. 2 10-02-2009 02:45 PM
Drag Bags anyone!!?? ZXGTO.com 2004-2006 GTO General Discussion 9 02-24-2008 05:31 PM
Air Lift Bags/drag Bags speedwrenchx10 Service, Maintenance and Technical Discussion 4 06-10-2006 07:06 AM
DRAG BAGs? alptbird Drive train, suspension, alignment and brakes. 7 03-20-2006 09:20 PM
