Driveshaft center support bearing - Pontiac GTO Forum
 1Likes
  • 1 Post By GTO44
post #1 of 7 (permalink) Old 10-12-2016, 05:18 PM Thread Starter
Quoted: 11 Post(s)
Can this be changed without removing the cat back exhaust?
Plowboy is offline
post #2 of 7 (permalink) Old 10-12-2016, 05:30 PM
GTO44's Avatar
Quoted: 38 Post(s)
You have to remove the drive shaft in order to separate it to replace the carrier bearing. So yes you will have to drop the exhaust to get the DS out.
Plowboy likes this.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 7 (permalink) Old 10-12-2016, 10:39 PM Thread Starter
Quoted: 11 Post(s)
I was hoping I could get away with not removing it since I just did the new borla cat back but no such luck.
Plowboy is offline
post #4 of 7 (permalink) Old 10-13-2016, 11:32 AM
AlaGreyGoat's Avatar
You may be able to disconnect the exhaust at the resonators, and drop it down enough to remove the drive shaft.
Larry
AlaGreyGoat is online now
post #5 of 7 (permalink) Old 10-13-2016, 01:20 PM
GTO44's Avatar
Quoted: 38 Post(s)
Good point Larry
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #6 of 7 (permalink) Old 09-03-2017, 11:12 AM
how do you seperate the two sections of center carrier bearing from drive shaft?
lynnadams16 is offline
post #7 of 7 (permalink) Old 09-04-2017, 08:54 AM
Yes, they are splined together and are tight. The bearing is a
tight fit, also.
Larry
Infamous Driveshaft Center Support Bearing 1967&2006gto 2004-2006 GTO General Discussion 12 08-31-2017 03:05 PM
Where to find a carrier bearing (driveshaft) KennedyKustoms Drive train, suspension, alignment and brakes. 7 08-11-2015 10:24 AM
Repair solution for driveshaft center bearing support (part 2) kaynine364 Drive train, suspension, alignment and brakes. 1 11-20-2013 04:14 PM
Solution repair on driveshaft center bearing support (Part 1) kaynine364 Drive train, suspension, alignment and brakes. 0 11-19-2013 05:24 PM
Differential Pinion bearing and driveshaft bearing support (05 GTO) bonso Drive train, suspension, alignment and brakes. 9 06-04-2012 09:32 AM
