Driveshaft Couplings - Pontiac GTO Forum
post #1 of 11 (permalink) Old 03-11-2010, 03:27 PM Thread Starter
KyleGT05usmc's Avatar
Saw a link to a really nice coupling that was polyurethane and i think intended for a corvette and cant seem to find that link anymore.
Need to replace my couplings, anyone have a good link?
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
post #2 of 11 (permalink) Old 03-11-2010, 05:16 PM
I copied this eBay link from a thread in here...couldn't believe the dealers want $330 EACH for these things, and yet they're $50 on eBay (for a 'Vette)...go figure...
Corvette C5 ZO6 Torque Tube Bushing 12 mm LS1 LS6 Z06 4 : eBay Motors (item 120348597532 end time Apr-05-10 12:45:30 PDT)
socal1200r is offline
post #3 of 11 (permalink) Old 03-11-2010, 07:16 PM Thread Starter
Well i was looking at ls1gto's forum about the prothane coupler. theyre metal except for the bushing right around each of the metal sleeves. now they come in 10mm or 12mm, guessing for an 05, a 12mm would do?
theyre built for corvettes, i called prothane and asked if theyre work the guy says "it doesnt say anything about gtos here" and was rushing to get off the phone... but from the ls1 forum it sounds like it might be possible. someone mentioned bmw,vette,gto shared same coupler around these years.
Corvette Torque Tube Coupler, Polyurethane, 12mm, 2001-2004
a little pricey but im not sure if theyd work. big price to experiment with lol
post #4 of 11 (permalink) Old 03-13-2010, 10:26 AM
The vette will not work its to small,we are working on a solution but it will be a month or so..
Hendrix-Engineering is offline
post #5 of 11 (permalink) Old 03-13-2010, 03:58 PM
Even at $150 I think a part like that is still WAY overpriced. From what I've heard on poly bushings, depending on the application, it stiffens the ride and makes it worse. At least the rubber has some "give", and doesn't stiffen the ride so much. I haven't bought a GTO (yet), so discussions like these definitely get my attention. I realize the car itself is assembled in Australia, but parts like these should not cost this much! There's gotta be a part like that for another car that will work perfectly for a GTO. I can't imagine a part like that is GTO-specific, but maybe I'm wrong...
post #6 of 11 (permalink) Old 03-14-2010, 03:55 PM Thread Starter
What source do most people get the stock or same as stock couplings from? I'm just gonna get a pair of those..
post #7 of 11 (permalink) Old 03-17-2010, 06:59 PM
You have to buy the complete ds from gm,as of yet there is no aftermarket replacement.We are looking into making them but at such low volume it would be well in the $300 range for the pair.
post #8 of 11 (permalink) Old 03-17-2010, 11:11 PM
GM4life's Avatar
If I had to buy a pair I would buy a 1-piece DS.
GM4life is offline
post #9 of 11 (permalink) Old 03-18-2010, 02:35 AM
AlaGreyGoat's Avatar
Just ran this on gmpartsdirect:
GM PART # 92149040
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $276.51
OUR PRICE: $163.91
DESCRIPTION: COUPLING
Here are the spec that I found:
Front & Rear Rubber Drive Coupling (Donut) Part No 92148358 (FOR 04 92149040 for 05)
Manufacturer Hardy Spicer
Mfg Part No RCA-1061
Comes complete with 100-R324 Coupling, 3 bolts, 3 lock nuts.
VX,VY,VZ V8's 10/00 on
04 (92148358)........................05-06 (92149040)
PCD=96mm 3.78in...................110mm 4.33in
Bolt Dia=12mm .472in................same
OD=133mm 5.24in...................150mm 5.91in
Bore=49mm 1.93in....................60mm 2.36in
Width=35mm 1.38in...................same (Metal tubes stick out 3mm, 3 on each side)
I measured my spare and is the same as listed for 05.
I have been told the C5 vette was the same, but as stated, may not.
On one of the other sites, it was stated some BMW coupler are the same.
Contact fparts on eBay. They can probably get you a used one, cheap.
Larry
AlaGreyGoat is offline
post #10 of 11 (permalink) Old 03-19-2010, 08:34 AM
If you ever get a GTO get used to it. Most parts are 1 1/2 to 2 times as much except of course most of the engine parts.
Driveshaft question spidersinmybed Drive train, suspension, alignment and brakes. 1 01-20-2007 08:37 AM
Driveshaft GTODAVE05 2004-2006 GTO General Discussion 9 06-06-2005 08:44 AM
Weak Driveshaft? scgoat Service, Maintenance and Technical Discussion 6 02-22-2005 11:25 PM
