droning noise in an 05 GTO - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-30-2013, 12:36 PM Thread Starter
I have an 05 GTO, auto trans. While driving, whether in gear, neutral, braking or coasting, I have this droning noise that increases or slows corresponding to vehicle speed. I'm thinking its the driveshaft, possibly the rear end, but it sounds and feels more like its not that far back. It's something that keeps turning with the wheels, but is not effected by braking, accelerating or coasting in neutral. Could possibly be a wheel bearing, but I don't have any play in my bearings
Any thoughts?
fishagto is offline
post #2 of 4 (permalink) Old 11-30-2013, 01:20 PM
Steamwalker's Avatar
Still could be wheel bearings. If there's play in the wheel, that's probably a sign you waited too long to replace it.
Also could be the tires. Some are louder than others.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #3 of 4 (permalink) Old 12-02-2013, 11:28 AM Thread Starter
The only play I have is in the right front wheel, and it's only front to back horizontal play and I can see the ball joint in the tie rod end moving slightly. A wheel bearing will typically have play in all directions in my experience, but have also seen bad bearings that had zero play but did have a droning sound. The rhythm of the droning noise isn't as fast as most bad bearings that I have heard. It sounds like something spinning slower than the driveshaft or wheels. It's almost like a bad harmonic vibration noise.
I just bought the car and never noticed the noise while test driving. I've got a 50/50 parts and labor warranty on the drive train. If I can pin point the problem, I'll probably try to get the dealership to cover 100% of the part and I'll fix/replace myself.
fishagto is offline
post #4 of 4 (permalink) Old 12-02-2013, 11:51 AM
The dealership diagnosed my sound as a rear wheel bearing. Had a shop replace the bearing but sound is still there. I just chalk it up to my new tires as the sound began shortly after I got them.
06/QSM/A4
SoCal Goat Club
Strange GTO Noise/Problem...Help! Baaaa04GTO 2004-2006 GTO General Discussion 2 07-20-2011 10:03 AM
06 GTO brake noise. Gunslinger 2004-2006 GTO General Discussion 7 04-25-2010 03:58 PM
New GTO and steering noise Xrover Drive train, suspension, alignment and brakes. 11 02-26-2007 04:29 PM
04 GTO tranny noise GTOgator Drive train, suspension, alignment and brakes. 2 11-07-2005 03:11 PM
04 gto brake pedal noise hanymahi Service, Maintenance and Technical Discussion 2 04-30-2005 12:43 PM
