Emergency Brake Need Help - Pontiac GTO Forum
post #1 of 1 (permalink) Old 04-15-2015, 01:41 PM Thread Starter
So towards the end of last fall my e-brake was not holding, I then did some research and found out you could make e-brake adjustments at the lever itsself... I tightened the tension on that cable and had to tighten it significantly. The problem was that it was holding but it would stick once the lever was released. Now its sitting there useless because I loosened the adjustment at the handle all the way.
Does anyone have any advice or at least a diagram of the components that I can reference? Maybe the cables need to be greased or something?
evanpatchay is offline
Emergency Brake cable advice needed nineteen 65 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 11-11-2013 09:38 PM
Emergency Brake Clicker chuckD Drive train, suspension, alignment and brakes. 9 03-17-2011 08:24 AM
emergency brake cables Gremlin66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 11 01-22-2010 09:35 PM
Emergency Trunk Release hsv 2004-2006 GTO General Discussion 4 11-03-2008 12:42 PM
