Flywheel and clutch - Pontiac GTO Forum
post #1 of 5 (permalink) Old Yesterday, 08:36 AM Thread Starter
Flywheel and clutch
I am putting a 1971 400 with muncie four speed in a 1967 gto the muncie is a 1967 yr what size clutch and flywheel would i need to get how many different sizes came in 1967 ?
Joseph Emmett is offline
post #2 of 5 (permalink) Old Yesterday, 09:12 AM
dcoydad's Avatar
Quoted: 6 Post(s)
I'd go with Hayes 11"
dcoydad is offline
post #3 of 5 (permalink) Old Yesterday, 02:09 PM
BLK69JUDGE's Avatar
Quoted: 33 Post(s)
they had 10.5 and 11" ..
not all ORIGINAL flywheels are drilled for the 11"
most were 10.5
most all aftermarkets are drilled for both sizes
some original HIGH horse big cube were just original PONTIAC flwheels were 11" only
go with a diaphram clutch cover ... I like Center force ..
Scott
BLK69JUDGE is online now
post #4 of 5 (permalink) Old Yesterday, 07:02 PM
Quoted: 312 Post(s)
The Hays flywheel is drilled for both 10.5" and 11".
Use an 11" diaphram style pressure plate along with a matching 11" disc. Bigger disc provides more surface area to grab and you can benefit from a lighter spring pressure which makes your pedal pressure better.
Most clutch manufacturers have listings which will tell you what to expect from the pressure plate/disc set-up. There are different clutch materials to consider as well, some better for street while others are best for racing.
Where most get into trouble is to make sure you get the correct matching throw-out bearing not only for the set-up, but for your car. Often when you buy a kit, you get a Chevy application throw-out bearing which is too short in most instances. Then you push in the clutch and you can't get a clean release........then you have to pull everything apart again to install the correct length bearing. I have enclosed a photo as an example only, so you can see what I mean.
Name:	Long vs Short.jpg
post #5 of 5 (permalink) Old Today, 07:42 AM
Quoted: 120 Post(s)
I just went with a McLeod 11" flywheel and clutch. The pedal is very easy for every day driving. I am still breaking in the clutch (gently), so I cannot comment on how well it holds, but I am sure it will do just fine.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
cij911
LS3 Clutch and Flywheel upgrade Bryce108 Drive train, suspension, alignment and brakes. 0 05-29-2017 08:17 PM
fidanza twin clutch and flywheel? banshee 2004-2006 GTO General Discussion 4 07-29-2008 09:24 PM
Clutch / flywheel opinions sdgoat Service, Maintenance and Technical Discussion 2 05-11-2006 07:27 PM
