Gear oil question - Pontiac GTO Forum
post #1 of 21 (permalink) Old 07-10-2010, 10:07 AM Thread Starter
Lukemo2's Avatar
Gear oil question
I'm going to change the differential fluid in my '04. I've done a lot of reading on this, and I've learned that if I don't use the GM part or Royal Purple, I have to add friction modifier to the oil.
I have not been able to find Royal Purple or the GM stuff in any of the stores or dealerships around here. I have purchased Mobile 1 full synthetic 80W140 gear oil, but I don't know what the friction modifier is called, how much to use, and how to use it.
Can anyone enlighten me?
Thanks~
Lukemo2 is offline
post #2 of 21 (permalink) Old 07-10-2010, 10:38 AM
They come in bottles of like 4-7 ounces. I've never been in a parts store that doesn't carry them. Even the Dodge dealership in my town carries it and it's all the same stuff. You can use a whole bottle. You can get it from summit. I believe they carry REDLINE.
K&W makes one, ATP makes one. Is their an O'reillys in your town?
Many synthetic gear lubes have the limited slip additive built in so I would read the label on the Mobil1 that you purchased and see what it says.
Here the GM part number:
GM Performance 1052358 Limited Slip Lubricant Additive 4oz
mikes06goat is offline
post #3 of 21 (permalink) Old 07-10-2010, 08:05 PM
jpalamar's Avatar
I used RP in my trans and diff. No complaints after 20k miles after the chainge.
jpalamar is offline
post #4 of 21 (permalink) Old 07-11-2010, 12:42 AM
GM4life's Avatar
The original specs for the GTO was:
75w-140 synthetic for the gear oil and 1oz for friction modifier
Royal Purple is a hit and miss, I had problems with it and others have too. Torco Type F seems to work best and thats what I use along with their limited slip additive. I used the whole bottle of limited slip additive without problems.
GM4life is offline
post #5 of 21 (permalink) Old 07-11-2010, 07:33 AM
srs7324's Avatar
Pontica GTOGear Oil
75w140 Mobile 1 Sythetic with a small amount of friction additive was what I used.
20 dollars a bottle at Advance.
All others appeared to be non synthetic and just run of the mill oil with no aditivies or additional properties.
NAPA did carry a friction modifier, but they have to order it overnight.
srs7324 is offline
post #6 of 21 (permalink) Old 07-11-2010, 07:47 AM
srs7324's Avatar
Gear Oil Additives
After reading up on a number of premium Synthetic Gear Oils, they all basically state that a Friction Modifier is not necessary and may cause harm if added.
NOTE: Synthetic Gear Lubes do not require the use of this additive.
However, not all differentials respond the same and if chatter is noticed, the addition of Friction Modifiers will eliminate it.
For chattering differentials not running Synthetic Gear Lube, this type of product is an excellent solution to the problem.
So it is my assumption that if you use run of the mill 75W140 gear oil, a Friction modifier is necessary, but if you purchase a Synthetic such as Mobile 1 or AMSOIL it is only needed on a case by case basis.
Just an FYI.
srs7324 is offline
post #7 of 21 (permalink) Old 07-11-2010, 10:52 AM Thread Starter
Lukemo2's Avatar
To add or not to add... that is the question.
Here is what I found on the mobile 1 website:
"Mobil 1 Synthetic Gear Lube 75W-140 LS contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid."
I am going to add about an ounce of friction modifier. I think I'll just go to the local dealer and order the GM performance limited slip additive. I would probably be safe without it, but I don't want to risk it.
Lukemo2 is offline
post #8 of 21 (permalink) Old 07-11-2010, 10:59 AM
ROBSGTO's Avatar
Wasn't tryting to highjack your thread,post was deleted.
Hope you get your answer,but on the other forum there is a GM parts sponsor that can get you the new GM fluid with friction modifier already in it.
Performance:230/232 .614 .602 114 cam,Kooks 1 3/4 headers/catted mids,Spintech,CSP ported intake/tb,UDP,tune by CSP.
Suspension:Pedders big bore shocks,GSR II struts,Lovells RR bushings,Kings 0 drop rears/20mm drop fronts.
ROBSGTO is offline
post #9 of 21 (permalink) Old 07-11-2010, 04:27 PM
GM4life's Avatar
The important thing is manufactures of gear oils do not build the rear ends, how would they know what the rear end needs or don't need. I think GM/Dana does more testing on the rear end than a gear oil manufacture. They know whats best for it. You run a diff without sometype of LSD additive if you want to and see how much noise its going to make. Our rear ends are a cone type not a clutch type. Thats the reason why people use a type F friction modifier than the type G for GM rears with Torco.
GM4life is offline
post #10 of 21 (permalink) Old 07-13-2010, 12:42 PM
i went with amsoil 75w 140 and there friction modifier its been a month. no problems
lingenfelter cai, vararam tb spacer, v/max ported tb, livernoise stage 2 heads with comp cam 232/232/.50 114 lsa. slp 1 3/4 headers high flow cats, x pipe, qtp cut outs, flowmaster mufflers. tuned by tt performance , highly recomended in n.j.
NEXSTAR7 is offline
1964 GTO intake, carb , and rear gear question. CCLGTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 08-17-2009 08:43 AM
gear oil? AlanSr Service, Maintenance and Technical Discussion 9 07-02-2009 07:05 AM
Speedometer Gear Question jpdog357 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-16-2007 09:28 PM
Gear Lube Question rrathea Service, Maintenance and Technical Discussion 6 05-28-2006 11:09 AM
rear end gear ratio question matt68gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 04-03-2006 10:30 AM
