Gear Ratios - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-23-2016, 04:23 PM Thread Starter
Quoted: 4 Post(s)
Gear Ratios
I believe the stock ratio in all GTO's all years A4 and M6 is 3.46. But whats a good ratio, for mostly daily use with occasional track use?
Bryce108 is offline
post #2 of 5 (permalink) Old 08-23-2016, 11:31 PM
GTO44's Avatar
Quoted: 37 Post(s)
Are you auto or m6?
What's done to the car?
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 5 (permalink) Old 08-25-2016, 06:49 PM Thread Starter
Quoted: 4 Post(s)
Originally Posted by GTO44 View Post
Are you auto or m6?
Bone stock, besides, a K&N intake, xpipes and mufflers. But it will soon, have OBX LT headers, LS7 clutch, and a tune. and sometime after tax season some kinda BTR cam
Bryce108 is offline
post #4 of 5 (permalink) Old 08-26-2016, 08:57 AM
GTO44's Avatar
Quoted: 37 Post(s)
Ah gotcha, didn't realize it was you from the other post.
I still have the 3.46 gears. They are great for the street and gas mileage. I've found them great for roll racing.
3.91's I've heard really wake the car up. A lot of people say they make it more fun to drive. You'll have to shift more and you might have traction issues in first gear. At the track 3.91's really help the M6 goats come out of the hole without bogging. Especially with sticky tires. These gears are going to be more at home at the drag strip for a lightly modded GTO then 3.46 or 3.73's. If your going with a decent size cam soon 3.91's would help the car down low and get the motor to the power band sooner so the cam can pull up top. I've really wanted to try these gears for a long time.
I think 3.73's are a happy medium. You get a little more grunt downlow to help get the heavy car moving compared to 3.46. Gas milage won't be too far off what it is now. I think these gears would be more at home on a road coarse then 3.91's which I'm setting the car up for. And still help with getting off the line at the drag strip which i like to do occasionally. I think they would also match up better with a smaller cam then the 3.91's as a smaller cam usually has more torque down down low. After talking to a GTO diff builder expert, If i decide to do gears these are the ones I would prolly get.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #5 of 5 (permalink) Old 08-26-2016, 06:02 PM Thread Starter
Quoted: 4 Post(s)
yeah, well like i said mostly street driven with occasional drag strip use lol BTR mentioned to me the LS3 stage 3 cam, because i want to put ported LS3 heads and intake on her at some point.
Bryce108 is offline
Gear Ratios dahd11 1964-1974 Tempest, Lemans & GTO General Discussion 17 12-31-2016 11:06 PM
gear ratios nubee12 Drive train, suspension, alignment and brakes. 2 07-03-2012 05:48 PM
Speedometer Drive Gear and Driven GEAR timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2012 03:48 PM
Determining ratios asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-07-2010 03:06 PM
Not Going into Gear?! 05LS2FAST 2004-2006 GTO General Discussion 6 09-15-2008 08:33 PM
