Grinding into gears!! - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-27-2010, 06:21 PM Thread Starter
2004 gto 6spd standard. I cannot go into first gear at all if im rolling. i have to be completely stopped and it still grinds putting it into first. Also i can be downshifting and sometimes it will do it with second gear aswell. my first thought was synchonizer, then my shifter cuz its the factory ****ty gto shifter and it pulls outta socket if i shift too hard, and ive been told its cheaper to just replace the tranny with a used one rather than deal with this at all. help me out someone. thanks
KennedyKustoms is offline
post #2 of 7 (permalink) Old 03-27-2010, 10:57 PM Thread Starter
ps... It doesnt grind at all getting on it from 1st to 6th. just down shifting
post #3 of 7 (permalink) Old 03-28-2010, 06:07 PM
jpalamar's Avatar
When was the last time you changed your trans fluid?
04 GTO - sold
jpalamar is offline
post #4 of 7 (permalink) Old 03-28-2010, 10:58 PM Thread Starter
Got the car w'out engine. just built the car up and changed it then. The car only had 47k miles on it but its a possibility its not even tha stock one. it was twin turbo'd on a 408 stroker when he blew it...
post #5 of 7 (permalink) Old 03-30-2010, 10:45 PM
Do a fluid swap first off.
post #6 of 7 (permalink) Old 03-31-2010, 01:00 AM
AlaGreyGoat's Avatar
47k behind a TT 408 Stroker would be about the same
abuse as a million miles behind a stock GTO.
Larry
AlaGreyGoat is online now
post #7 of 7 (permalink) Old 11-05-2010, 11:19 AM
BlueTiger's Avatar
Mine is doing the samething. I replaced the fluid in the trans and flushed the clutch fluid and replaced with fresh fluid and still the samething. Right now, Im looking at a $1400 rebuild.
2004 Pontiac GTO Impulse Blue M6
Custom Tune by RunninWithTheDevil
304 rwhp 335 rwtq
BlueTiger is offline
Grinding DBrac37 Service, Maintenance and Technical Discussion 3 01-24-2010 11:36 AM
grinding in reverse simmons68 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-02-2010 07:07 PM
Grinding noise Lori Ori Drive train, suspension, alignment and brakes. 1 11-26-2009 03:14 PM
Clunking/grinding when turning Michael.Narlock Service, Maintenance and Technical Discussion 11 02-01-2009 12:13 AM
Grinding Noise mendozar 2004-2006 GTO General Discussion 5 07-03-2007 07:38 PM
