Grinding noise - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-26-2009, 02:33 PM Thread Starter
Grinding noise
Hello,
I was hoping someone would be able to help me out...
I have a 2005 GTO 6.0 and recently I have been noticing a grinding noise when starting out in 1st gear (as the clutch is released) and my monitor says 'low traction'. I hear the noise in the rear of the passenger side. It doesn't do it every single time coming out of 1st, but at least 2-3 times a day. I had a mechanic at Firestone take it for a test drive while getting some new tires and of course it didn't do it for him...Any ideas of what this could be?
Lori Ori is offline
post #2 of 2 (permalink) Old 11-26-2009, 03:14 PM
When the GTO senses a loss of traction it will apply the brakes to the spinning wheel to add traction to the other wheel. You may have a bad traction sensor. Turn off the traction control and see if the problem stops.
05GTO is offline
grinding noise coming from rear end banshee Service, Maintenance and Technical Discussion 2 08-07-2008 06:54 PM
Grinding noise when shifting from 1st to 2nd gear? O'Town Service, Maintenance and Technical Discussion 19 02-08-2008 05:07 PM
Grinding Noise mendozar 2004-2006 GTO General Discussion 5 07-03-2007 07:38 PM
grinding noise after shifter install???? WhoaGTO Drive train, suspension, alignment and brakes. 2 07-19-2006 07:59 PM
Grinding noise fixed, good work Sewell VYSSUTE Service, Maintenance and Technical Discussion 2 03-17-2005 05:41 PM
