Hello im new to gto had a question - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-23-2013, 04:39 AM Thread Starter
Hello everyone ive been reading on this forum, and I was wondering whats everyones opinion on a big bore rear shocks and a 35mm lift spring with a 1/2 front drop. Anyone with pros and cons of this set up it would be appreciated the car is a dd only during summer but I do like draging it but want that good cornering
Thanks jake
redgoatjake92 is offline
post #2 of 4 (permalink) Old 11-24-2013, 08:14 AM Thread Starter
Bump anyone?
post #3 of 4 (permalink) Old 11-25-2013, 07:09 AM
I would determine what you want the car to do because it cannot do everything great. A good drag car will not handle great on the street and a well handling car will not be great at the strip. Also, the 04 rear suspension is weaker than the 05/06, so that should be taken into consideration. Being a DD I don't think a drag oriented car would be that great but there are some things that could be altered such as airbags in the rear springs.
Peddars stuff is good but a little overpriced; look into Whiteline specifically purchased from Kollar Racing.
Also, depending on where you live somewhat dictates the ride height you can accommodate. I installed the 25/30mm drop Lovells Eliminator kit in my car. I find it very street able but if I lived in SoCal it would not be a good option due to the water channels located at intersections (I don't know what they are called). But personally, in stock form I think they sit like Subarus so they need to be dropped.
There is a lot of information over on Ls1GTO.com regarding what stock components to replace as soon as possible or I could let you know either here or via PM. I am by no means an expert on these cars but have learned quite a but over the last year of ownership; my forte is more 67 GTOs.
younggto is offline
post #4 of 4 (permalink) Old 11-25-2013, 10:58 AM
Raised in the back and dropped in the front? Just no for everything
post #5 of 4 (permalink) Old 12-13-2013, 06:41 PM
NucciGOAT's Avatar
Please inform me on what should be replaced ASAP besides the springs/shocks. I know that. I just need the funds. But other the radius rod bushings and obviously the strut mount bushings that will be replaced when I replace the struts springs. What bushings are most critical after that?
Sent from AutoGuide.com App
2004 yellow jacket M6: AEM intake, SLP LM2, 05/06 front brakes with DBA slotted rotors & hawk pads, B&M shifter, MSD wires, NGK TR55 plugs, Diablo predator tuned..
NucciGOAT is offline
68 gto value question joedee 1964-1974 Tempest, Lemans & GTO General Discussion 3 11-19-2013 03:20 PM
65 gto question Baahhhh 1964-1974 Tempest, Lemans & GTO General Discussion 12 03-15-2011 09:18 AM
HP question(Non GTO) ROBSGTO The Lounge 9 03-20-2009 09:52 PM
Question about 07 GTO NateDog 2004-2006 GTO General Discussion 11 11-24-2005 10:07 AM
