Help with front tire rubbing on strut mount - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-18-2009, 06:45 PM Thread Starter
I have a 04 GTO and just noticed that both front tires have the cords showing on the inside of the tire only. This didnt make since to me since i just rotated the tires a month ago and had it aligned, and havent hit anything noticeable. So i looked a little harder and noticed the the inside of the tires are rubing on the top of the strut.........Is this thing out of alinment oR what? Anyone heard of this before? Nothing looks to be bend. Going to take it back to the aliment shop tomarrow, but its got me puzzled.
Tire size is 245/45zr17 Bfg G force T/A
bwhit is offline
post #2 of 7 (permalink) Old 07-18-2009, 07:00 PM
badgoat91's Avatar
ya this is one of the most common problems with the goats, thats why you see everyone going with those pedder setups. but idk i havent tried it on mine, i just drive my car and when they rub oh well haha, and i autocross quite a bit
badgoat91 is offline
post #3 of 7 (permalink) Old 07-18-2009, 07:34 PM Thread Starter
So are they most likely rubing when cornering and the suspension is compressing and leaning? Cause just sitting flat in the driveway and turning right to left no rubbing, but i do have visual marks on the strut.
And whats the pedder setups?
THANKS
bwhit is offline
post #4 of 7 (permalink) Old 07-18-2009, 08:52 PM
THANKS
Don't be driving your car with cords showing, that's just stupid, no offense to the guy who autocrosses at 45 mph on a closed course, but mountain road twisties and interstate on-ramps are different worlds.
You probably have strut rub due to to some compressed bushings/bearings on the front end. Pedders is the most prominent aftermarket suspension maker for late model GTO's. You probably have a local dealer near you, but I found this. If you're into handling, you may go for a larger suspension kit with more parts.
RocksandRacing, LLC : GTO Strut Rub Kit - GTO-SRBK
I imagine a Pedders sponsor may chime in on this thread
fattirewilly is offline
post #5 of 7 (permalink) Old 07-18-2009, 11:21 PM
ROBSGTO's Avatar
Along with the strut mounts and bearings don't forget to install new radius rod bushings as well.
ROBSGTO is offline
post #6 of 7 (permalink) Old 07-20-2009, 01:44 PM
jpalamar's Avatar
Rocksand is a great shop. Frank will be glad to help you.
04 GTO - sold
jpalamar is offline
post #7 of 7 (permalink) Old 08-09-2009, 02:22 PM
dms
dms's Avatar
As already mentioned, this is 1 of the several "deadly sins" of the GTO. Most of the inside tire wear, which could be accompanied by some mild strut rub, is a function of excess movement, which will cause camber, caster and then the serious one, toe change. The upper strut bushings are the biggest culprit, and can get darn right scary bad. So doing the Pedders front tire rub kit, and then re-aligning to get at least 1/4 inch clearance will resolve it. Make sure nothing else is loose as well.
Here is Pedders strut rub kit:
2/4/09 PEDDERS STRUT RUB TIRE WEAR UPDATE
MERLIN STORE P/N GTOTIRERUBPACK
The GTO has been prone to front tire wear concerns, primarily on the inside edges. Some
due to sture to tire contact, but mostly due to poor control of the upper strut position
and the excess lower control arm movement on braking, cornering, and acceleration
This kit offers the fix and method to significantly improve front tire wear.
A save strut to tire clearance factor is the width of a pencil. Also it is critical
to keep and maintain appropriate tire pressures as indicated on your placard
Part # Component
4306 GTO Strut Clevis Bolt and Nut Package, Single Use
4358 GTO Bump Stop Front Requires 2 packages
5030 GTO Strut Bearing.
5851 GTO eXtreme Strut Mount
EP9166 GTO Urethane Front Radius rod bushings and caster adjusters
PDUSA5409 Pont GTO 5409 Replacement Front Radius Rod Nut. Gm P/N 11076363
then you face some other opportuniites. It takes the same amount of work to do the struts and coils as it does to do the strut bushings. And since yours is a 04, with probably some mileage on it, you may also want to consider struts and coils.
mike
dms
Michael White
DMS Doing Mike's Stuff
dms is offline
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Discount Tire Announces New 2009 Driver for FormulaD Discount Tire In the News 0 11-18-2008 02:22 PM
Identifying Tires: Production Date, Speed Rating, & Load Range GTO JUDGE Wheels and tires 0 05-10-2008 06:53 AM
Strange issue with Flat tire at Dealership. GTOtbird Service, Maintenance and Technical Discussion 7 12-30-2006 01:22 PM
