High RPM/Speed Trans. Leak - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-10-2009, 11:32 PM Thread Starter
I have a modded '06 GTO and am having trouble with the transmission on high gear, high rpm pulls. Had it do it once in 3rd gear and again tonight in 5th gear. Tonight I had the car in 5th gear on the highway around 2500revs, laid into the throttle and ran it out to around 5k revs (maybe a bit more). As I was climbing in the Rev range, I saw a trail of white smoke behind me. I pulled over and saw the floorpan as well as the collector area of the headers dripping with Trans fluid. I am hoping someone has some sort of answer as to what might be causing this.
Car has 507RWHP/465RWTQ
BMR Fab Solid Driveshaft
Kaaz LSD, 3.92 Gears
BMR Halfshafts
Textralia Clutch
bmac44514 is offline
post #2 of 6 (permalink) Old 09-11-2009, 06:37 AM
B-ville Goat's Avatar
Maybe the tailshaft seal is leaking? I would look there first especially since you have an aftermarket driveshaft.
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
post #3 of 6 (permalink) Old 09-11-2009, 10:10 AM Thread Starter
Tailshaft seal had been replaced with a new OEM seal and still leaks. Slip yoke on driveshaft has been replaced as well.
post #4 of 6 (permalink) Old 09-13-2009, 07:36 AM
GM4life's Avatar
Front seal??
GM4life is offline
post #5 of 6 (permalink) Old 09-18-2009, 01:37 PM
See if any of the gaskets are leaking.
Poncho Dan is offline
post #6 of 6 (permalink) Old 09-18-2009, 05:23 PM Thread Starter
The B&M short shifter bolts stripped and allowed the shifter to lift up and open the top of the tranny up to leak at high RPM's. A few helicoils and some elbow grease and all is well. Thanks everyone for your help.
Trans cooler lines teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-03-2009 06:37 AM
Engine code and date discrepancy - HELP!! Mcantw 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 16 02-13-2009 09:04 PM
Trans Leak RipTheSix Service, Maintenance and Technical Discussion 3 04-18-2008 05:30 PM
modern high performance koman The Lounge 7 04-04-2007 04:21 PM
