How to replaec a shifter? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-18-2009, 03:18 PM Thread Starter
Hi, i just got my hurst shifter and cant wait to install it.
The problem is that when i read a how to guide, i do not got the part where you have to get under the car and take 4 nuts out.
How to install B&M shifter
Can some one please explain where exactly are those nuts? maybe some one has a picture? i would really appreciate it!
Thanks in advance!
and yes i know i wrote replaced incorrectly!
rj91049 is offline
post #2 of 8 (permalink) Old 10-18-2009, 03:30 PM
AlaGreyGoat's Avatar
The white rubber shifter boot is mounted with a metal ring around the bottom.
It has 4 studs made on it, and they protrude through the floor, with nuts on the underside.
Two are easy to get at and the others a not very easy.
Larry
AlaGreyGoat is offline
post #3 of 8 (permalink) Old 10-18-2009, 03:34 PM
GM4life's Avatar
You have to jack up the car, get under it and look above the transmission. You should see four nuts above the transmission where the shifter sticks up through the passenger compartment. You may not see all of them because of the tranny is off-set and the bulk of it. You may have to use a wrench to remove them.
GM4life is offline
post #4 of 8 (permalink) Old 10-18-2009, 07:33 PM Thread Starter
ok thank you, today i got under a car and found it, How do i get the front 2 nuts? They look like hard to get.
Also what tools will i need to take the old (stock) shifter off?
I heard that i will need some triangular tool.. True?
rj91049 is offline
post #5 of 8 (permalink) Old 10-18-2009, 08:26 PM
GM4life's Avatar
Its been awhile since I done mine. You might have to lower the transmission by removing the four bolts the hold the transmission crossmember. No special tools needed, common tools will get you by.
GM4life is offline
post #6 of 8 (permalink) Old 10-18-2009, 08:52 PM Thread Starter
Please define common tools! Thanks for the help!
rj91049 is offline
post #7 of 8 (permalink) Old 10-19-2009, 06:09 PM
FastFrank's Avatar
I used a ratcheting end wrench with a pivoting head. These things have proven invaluable to me.
FastFrank is offline
post #8 of 8 (permalink) Old 10-19-2009, 08:03 PM Thread Starter
Thank You
rj91049 is offline
B&M Shifter feedback RicanGoat Drive train, suspension, alignment and brakes. 14 01-27-2012 10:16 AM
4spd shifter sticking between 2nd and 3rd sknight751 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-15-2009 06:25 PM
Lou's Short Stick Shifter? kegbelly Drive train, suspension, alignment and brakes. 6 03-20-2009 06:07 PM
I should have listened (B&M Shifter) t0ny Service, Maintenance and Technical Discussion 5 12-13-2005 02:46 AM
B&M Shifter - modification needed. LS2FAST Service, Maintenance and Technical Discussion 5 11-08-2005 08:14 PM
