Inner front tire tread wear - explain - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-18-2014, 08:21 PM Thread Starter
could you explain why replacing a few bushings fixes the strut rubbing? is it because the rubbing is so minor that the collapsed/worn bushings make that much of a difference in spacing??
Rgrafton is offline
post #2 of 3 (permalink) Old 03-21-2014, 09:31 AM
Things with nice sized tires do have close tolerances. The top of the strut is held in place by the strut bushing. It's a tire rub obviously as the strut is located inside the spring but keeping the geometry correct requires keeping the parts where they were designed to be.
post #3 of 3 (permalink) Old 03-23-2014, 02:14 PM
Steamwalker's Avatar
Link to the top: https://www.gtoforum.com/f39/definiti...oncerns-19058/
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
Question about where to put great tread tires up front or back?.... pctek Wheels and tires 6 11-30-2010 12:28 PM
Front Tire Wear - even with alignment BobS Drive train, suspension, alignment and brakes. 10 01-28-2010 11:16 PM
Tire wear? Kirk rubin Wheels and tires 3 04-15-2009 08:30 AM
strange front tire wear manny951 Drive train, suspension, alignment and brakes. 2 04-11-2009 03:22 PM
tire wear ramairws6 Service, Maintenance and Technical Discussion 4 01-21-2005 11:16 AM
