King springs - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-27-2015, 08:41 AM Thread Starter
King springs
My 2005 gto has king coil springs installed all the way around, Front are Part # KHFL-47 D/S Top , Rear part # KHRL-46 - S0720896810
Questions- What do all these numbers indicate? How much is my goat lowered front and back? What does D/S on front coils refer to? What are factory ride height specs and where are they measured? ,car runs great but a little stiff for my liking ( except for smooth roads), I would like to raise vehicle slightly and improve ride quality, is this possible? sorry too many questions!
Thanks!
torrid red sap is offline
post #2 of 4 (permalink) Old 05-29-2015, 04:35 PM
Those are heavy rate springs. Some people think that the firmer a ride the better the traction. That's true on a perfectly smooth road but a little more compliance has better traction on normal roads with expansion joints, bumps and such. Too stiff can cause the wheels to lose traction and/or contact with the ground.
You'd like Lovells a lot better. They are slightly firmer somewhere between stock and the Kings. Lovells measures from the center of the hub to the wheel opening. IMHO the 20mm drop spring is the best for all-around on this car. High enough for a good camber and ride and low enough for improved handling.
post #3 of 4 (permalink) Old 05-31-2015, 01:53 AM
Steamwalker's Avatar
I believe the KHFL-47 is a 1/2" drop in the front and the KHRL-46 is a 1" drop in the rear.
King Springs are known for being rather firm - especially the HD and HHD springs.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #4 of 4 (permalink) Old 05-31-2015, 10:25 AM
Ya with a rear drop that far you're going to have camber problems and thus abnormal tire wear especially if the rear inner and outer control arm bushings are stock
Front Springs - What brand/spec springs are you running? Jeff's Classics 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 11-26-2010 12:12 PM
King springs ROBSGTO Drive train, suspension, alignment and brakes. 4 06-17-2009 11:04 PM
All Haill The New GT King Groucho The Lounge 14 06-12-2005 11:00 AM
