Knocking sound from back end - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-15-2013, 01:51 AM Thread Starter
Ok so I just bought a 2006 GTO, 6 spd manual, car has 77k miles on it. A couple days ago I was leaving work and driving through town I noticed a fairly loud knocking sound coming from the back end. If I stayed in the gas just enough to keep the car rolling smoothly, it would go away, but as soon as I let out of it, or started to pull a little, it would come back. It's a constant knock, not just a single clunk like you usually hear. The sound was similar to a broken connecting rod in an engine, just slower.
So being a mechanic, I headed back to where I work so I could get the car on a lift and see if I could find out what was going on. Got it lifted up, spun the rear wheels a couple times and I heard the sound twice and then it went away, so I couldn't really get a definite pin point on it. I checked everything out back there just to be sure, couldn't find anything out of the ordinary. Diff felt nice and tight, axles felt fine, all suspension felt good. I haven't pulled the cover off the diff, don't really want to if I don't have to.
I have driven the car a good 150 miles since and haven't heard the noise again. It's just worrying me and I don't have the time to really dig into it. Not to mention I haven't ever heard anything like it.
Has anyone ever experienced something like this?
ShaderGT is offline
post #2 of 5 (permalink) Old 12-15-2013, 02:33 AM
Steamwalker's Avatar
How did your guibos and carrier bearing look?
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #3 of 5 (permalink) Old 12-15-2013, 02:47 AM Thread Starter
As far as I could tell they looked fine. This was a fairly slow knocking sound, no vibration that I could feel, honestly I wondered if an axle had somehow broken and was banging around. That's what it sounded like.
ShaderGT is offline
post #4 of 5 (permalink) Old 12-15-2013, 08:05 AM
NucciGOAT's Avatar
You sure you don't possibly have a loose exhaust back there tapping the body somewhere? Or something along those lines? Strange that it happened when you spun the wheels tho.. Hubs, bearings?? There's a lot of possibilities.
Sent from AutoGuide.com App
2004 yellow jacket M6: AEM intake, SLP LM2, 05/06 front brakes with DBA slotted rotors & hawk pads, B&M shifter, MSD wires, NGK TR55 plugs, Diablo predator tuned..
NucciGOAT is offline
post #5 of 5 (permalink) Old 01-23-2014, 11:54 AM
hemi1282's Avatar
I had a similar issue when I stopped and pulled off had a clunking noise, sound like somthin rolling around n trunk, it was the driveshaft slaming on the caring bearing the rubber seal done got damaged
hemi1282 is offline
HARd Crack sound rear end Bossin Service, Maintenance and Technical Discussion 4 09-08-2011 04:02 AM
front end banging/knocking xcmac26 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 12-07-2010 07:09 PM
Knocking Loms1977 Service, Maintenance and Technical Discussion 10 02-24-2010 03:05 PM
knocking/tapping sound? GTOsarge Service, Maintenance and Technical Discussion 25 07-06-2008 09:24 PM
Rattle-Clicking Sound in Back Seat PatrickNJ 2004-2006 GTO General Discussion 5 04-25-2006 06:36 AM
