lowered gto issues - Pontiac GTO Forum
post #1 of 19 (permalink) Old 07-22-2015, 12:12 PM Thread Starter
lowered gto issues
So I have never posted before, usually just lurk around and learn things. But yesterday I came across an issue that I cannot really find the answer I am looking for.
I bought my car with lovells lowering springs already on it, and it sits pretty low. I recently bought wheels for it, (19" VMR v701s). the rears fit perfectly fine, the issue I am having is with the fronts. from all the research for best tire size for these wheels that people run (245/40r19), mine rub fiercely on my struts. Is it because my car is lowered that this is happening? and I have determined that a couple ways I could go are:
1. 235/35/r19 tires
2. bc coilovers to gain more clearance
I tried to google it but i couldn't find anything, but would I have an issue going down to a 235/40r19? from what I can tell the tire is narrower and shorter than the 245/40, but i am not sure if it is enough.
I hope someone who has more knowledge with this subject can give me a hand. thanks
danf23 is offline
post #2 of 19 (permalink) Old 07-22-2015, 10:24 PM
I think your sidewall is too tall but I'm not sure if that is causing your strut rub. You could also consider adding a spacer. What are your wheel widths and offsets? If you have excessively negative camber that could also contribute.
Nice choice on the v701s. I'd like to see some pics.
zwarren is offline
post #3 of 19 (permalink) Old 07-23-2015, 03:06 AM
Spacers with arp studs and change the strut mounts and bearings. And that tire is tall. Car was designed for 17s/18s. By lowering it and putting bigger tires its probably gonna handle worse since you lose suspension travel and camber. Also i don't think there is a race car with a bigger than 18 wheel. Bet it looks good though
Qnko is offline
post #4 of 19 (permalink) Old 07-23-2015, 05:52 AM Thread Starter
well like I said I bought the car with the lowering springs. Its a little too low for my liking but it wasn't an issue when I had the factory 17s on it. I tried spacers but it brings my tire too close to the fender lip and it hits the fender lip so spacers are out of the question unfortunately.
wheels are 19x8.5 w/ 45mm offset
tires are 245/40r19
I have been told that going to the BC coilovers will give me the inner clearance to run the current tires, but unsure whether I want to spend the money right now or just get a pair of 225/40, a little on the skinnier side but it will give me the clearance I need while keeping a decent amount of tire I believe
danf23 is offline
post #5 of 19 (permalink) Old 07-23-2015, 05:55 AM Thread Starter
attached is a picture of what it looked like with the factory 17s plastidipped black (had no choice with that), and then the picture of the vmrs
ID:	61570   Click image for larger version
danf23 is offline
post #6 of 19 (permalink) Old 07-23-2015, 09:41 PM
Love the wheels and ride height. Are you sure the rear tires don't hit the fender lip? On the front, I have 18x8.5 w/ +35mm offset and 245/40/18 tires. I didn't have strut rub on the OEM struts and I don't now with BC coilovers. I don't have a problem clearing the fender lip either. If you added a 10mm spacer we would have the same strut clearance except for your extra sidewall height. I would avoid going to a narrower tire. Also check your strut mounts like Qnko said.
zwarren is offline
post #7 of 19 (permalink) Old 07-23-2015, 10:44 PM
Badkat's Avatar
Replace strut mounts. Replace stock front radius rod bushings with adjustable radius rod bushings. Get re-aligned.
Strut mounts - LOVELLS POLY STRUT MOUNTS & BEARINGS GTO G8 - Kollar Racing Products
Radius Rod Bushings - LOVELLS FRONT RADIUS ROD BUSHINGS -CASTER ADJUSTABLE PAIR-GTO - Kollar Racing Products
Google GTO strut rub problems and fixes. Very common on these cars, very easy to fix.....just need to spend a little cash on suspension upgrades.
The coil overs will of course help if you were willing to spend that much. And as far the tire size goes, you could go to 225's up front with no driveability issues. I run 225's in the front and 255's in the back with no problem at all on an 18" wheel. I am also lowered about 1".
Unless you drive like Mario Andretti and you plan on going through the Chicane at 100 mph, a narrower tire up front isnt going to effect you.
I assume you are going for looks and driveability, not performance, since you are running on 19's. Correct me if I'm wrong.
Mark - Plainfield, IL http://markquitterracing.com
2004 GTO A4 - LS1
Competition Cam
JBA LTH
K&N CAI
Yank 3600 Stall Speed
Flow Master exhaust
Dyno Tuned
Whiteline Suspension upgrades
B&G Lowering springs
Badkat is offline
post #8 of 19 (permalink) Old 07-24-2015, 05:32 AM Thread Starter
I ended up buying cheap 225's as a temporary fix until I can save up a bit of money to do the bushings and the coilovers, id like to be able to raise the front just a bit because I believe it is just a little too low for RI roads.
And no the rear tires dont hit the fender lip. The guy before me slightly rolled the fender lips so they are not an issue anymore.
haha no I dont drive like mario andretti, I get on it every now and then and have fun but I dont see this car having a future as a race car, maybe a drag strip once or twice a year but thats it. i actually only ended up with 19s because i found them with tires used for a good deal, but now that they are on I love how they look on the car.
thank you guys for your input and the parts links, if only money was never an issue haha
how extensive of a job is it to replace those parts? havent had to do much work to this car yet
danf23 is offline
post #9 of 19 (permalink) Old 07-24-2015, 10:27 AM
Badkat's Avatar
Good man! I forgot to mention the fender roll for the back, but you have it done already so your good to go there.
Strut mounts install............you need to pull the front strut out. Can be done by yourself with the right tools. Air gun/ratchet definately helpful especially for the top nut under the hood. Or just do what I did, you buy the parts (strut mounts w/ bearings), and find a local garage that will drop the struts and put them in for you for a reasonable price.
Radius Rod bushings you can do yourself. Only needed tools are a breaker bar and a torque wrench.
I just mentioned the Mario Andretti tire thing because I notice alot of people freak out on here about going to a smaller tire. If you like to fast turns or you road course, of course you dont want to run a smaller tire. Just normal driving, the 225 up front will work just fine. Straightline, or drag racing, I would put a bicycle tire on the front if I could get away with it! lol. Just dont go to a small tire in the back, ever. These cars have too much power not to have traction.
Good luck, and nice looking ride
2004 GTO A4 - LS1
Competition Cam
JBA LTH
K&N CAI
Flow Master exhaust
Dyno Tuned
Badkat is offline
post #10 of 19 (permalink) Old 07-24-2015, 10:44 AM Thread Starter
the only thing i would do to the rear now would mini tub it and put bigger tires in lol.
The tools and work I have no problem with, perks of having a shop with a lift. I just wasn't sure what all is involved with the work.
but with the fender rolling I need to fix the rear fenders.
Yes its a good thing it has been done....but it was done pretty hack.
As the car sits it looks like the passenger side was done with a hammer and the driver side was not touched. I believe when he did the lovells springs the rear cradle got misaligned which is why one fender is rolled and the other is not. I have no idea how to check to see if it is out of alignment and I don't even know where I can go to get the tool to fix it if it is.
If I ever decided to road course it in the future it would only be after all 4 corners getting coilovers and I would get a dedicated set of wheels for racing, but that is nowhere in my future. at the moment with all the things I have yet to fix that was either hacked or not taken care of.
danf23 is offline
Has anyone lowered they're GTO on H&R springs? PontiacKidd Drive train, suspension, alignment and brakes. 6 11-13-2014 08:57 PM
lowered 04 gto gto6767 Wheels and tires 1 07-20-2012 05:20 PM
Wheel/tire combo's for lowered 66 GTO Gas-Tires-Oil 1964-1974 Tempest, Lemans & GTO Wheels & Tires 13 04-11-2012 05:17 PM
Wheel/tire combo's for lowered 66 GTO Gas-Tires-Oil Wheels and tires 0 04-09-2012 09:30 AM
Any lowered GTO's in here? LIVEVIL 2004-2006 GTO General Discussion 13 09-20-2005 03:18 PM
