ls7 clutch master cylinder? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-25-2014, 09:33 AM Thread Starter
Send a message via MSN to Gto-noob Send a message via Skype™ to Gto-noob
will the ls7 clutch master cylinder work on the ls2 gto. My gto has the ls7 setup and I would prefer to utilize the ls7 slave cylinder. will this work?
Gto-noob is offline
post #2 of 2 (permalink) Old 11-25-2014, 02:05 PM
I know why you want to use the LS7 slave but it won't fit if you're trying to put it in a GTO. The transaxle is different on a Z06 than our transmission and thus the dimensions are different. The bellows are a nice touch but it only seals off the outside of the piston. The inside cylinder seal is where the input shaft goes through it and doesn't have a bellows. The best thing you can do is put on a remote bleeder on ours and bleed top to bottom frequently.
Z06 LS7 Clutch Slave Cylinder - LS1GTO.com Forums
clutch master cylinder plunger issue Triple6GTO Drive train, suspension, alignment and brakes. 0 11-14-2013 07:05 PM
Clutch Master cylinder johnfin Service, Maintenance and Technical Discussion 1 08-24-2013 03:13 AM
CYBER MONDAY at TICK PERFORMANCE: 5% off our Adjustable Clutch Master Cylinder Kits! [email protected] Drive train, suspension, alignment and brakes. 0 11-28-2011 12:13 PM
clutch master cylinder 04blueskys Drive train, suspension, alignment and brakes. 14 10-13-2011 01:51 PM
