LS7 clutch vs Monster Level 2 clutch - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-13-2009, 07:55 PM Thread Starter
POLGTO05's Avatar
Hallo, I own a 05 gto 6MT, almost stock.. i was wondersing if someone could point me up to the right derection.. Since my slave cylinder bearing is about to go out, im planning to replace the clutch, lines and bleeder too. I did some research on the ls7 it has a good rep on here. My question is about monster? anyone on here has any experience about which flywheel is better ? 28lbs SFI certified billet steel flywheel or 15lbs chromoly flywheel...
Thanks for all the help..
POLGTO05 is offline
post #2 of 6 (permalink) Old 05-14-2009, 05:42 AM
B-ville Goat's Avatar
If your staying close to stock the LS7 will be good for you. Monster has an awesome rep, too.
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
post #3 of 6 (permalink) Old 05-14-2009, 07:05 AM
SANDU002's Avatar
As stated before if you are staying close to stock or don't plan to go 500rwhp, I would go with the LS7 and spend the extra cash on something else.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #4 of 6 (permalink) Old 05-14-2009, 09:44 AM Thread Starter
POLGTO05's Avatar
Thanks all for the help..
POLGTO05 is offline
post #5 of 6 (permalink) Old 05-26-2010, 02:12 PM
Ls7
I would go with the LS7 since your car is stock. It will be closer to stock clutch engagement. I have heard good and bad things about Monster. Let me know how it works out if you go with Monster.
dngriffi is offline
post #6 of 6 (permalink) Old 05-26-2010, 07:18 PM
GM4life's Avatar
GM4life is offline
Buying a GTO, What's up with the Clutch? apicia 2004-2006 GTO General Discussion 9 03-12-2007 05:57 PM
Project: Yellow LS7 GTO 05GTO In the News 14 12-06-2006 10:00 PM
ls7 clutch unclebens Drive train, suspension, alignment and brakes. 2 08-06-2006 12:50 PM
Clunk when Lifting Clutch daveinsa 2004-2006 GTO General Discussion 6 06-17-2005 08:53 AM
